2006 6.0 Trouble code - Ford Powerstroke Diesel Forum
Old 02-17-2012, 05:39 PM
Im getting the P0236 Trouble code that has to do with the boost pressure sensor, the MAP sensor has just been replaced and still having boosting issues, only getting about 10psi full throttle. Please Help!
Old 02-17-2012, 06:23 PM
Powerstroke Techie
Assuming that MAP, BARO and EBP readings all indicate atmospheric pressure at key-on/engine-off within 1 psi of each other, the next step is to check the MAP sensor hose for blockage (carbon) as well as the intake. If this checks out, and there are no intake leaks between the turbo and intake (cracked CAC hoses etc.), it's time to pull the turbo for cleaning and/or replacement.
