Ficm Voltage - Ford Powerstroke Diesel Forum
Old 02-12-2012, 01:33 PM
Ficm Voltage
So it was really cold out (21deg) and when I started the truck my ficm voltage was bumping between 45v to 46.5v, then after running for 5min it jumped up to 48v. Should I be worried about it? Thanks in advance!
Old 02-12-2012, 10:50 PM
I think you are ok the cut off point is 45v and under so keep your eye on it are you running a 5w40 Syn oil this will help on cold starts.
2 stroker
Old 02-13-2012, 02:33 PM
Ok good im trying to hold off on any mods till springtime. I haven't been running Synthetic because i couldn't find it in 15w-40. I use shell rotella but only find the 5w-40 T6? Have you had good luck switching to synthetic? I change my oil religiously every 3000k. I did flush my coolant and used Restore and Restore plus cleaned it out and switched to CAT ELC and installed a coolant filter. My Delta is 9*.
Old 02-13-2012, 02:35 PM
Feedback Score: 3 reviews
Check your batteries also
Old 02-13-2012, 04:17 PM
A 5w40 Syn oil is the only way to go your injectors will love it plus with the Syn 5w40 you can go to 5k on the oil change no problems.
2 stroker
Old 02-14-2012, 06:19 AM
The Rotella T6 5w40 synthetic is what you want.
Old 02-14-2012, 07:32 PM
What do you guys think about running 5W-40 in the summer? In the Owners manual it said its only good to like 60* ambient temps? I live in Mass so its not too hot for long but it can get warm...
Old 02-14-2012, 11:23 PM
What is the difference between 5w40 and 15w40 just the cold side the hot side is the same. This is from Ford
SAE 5W-40 Full Synthetic Diesel Motor Oil
2 stroker
Old 02-15-2012, 03:44 AM
Yeah, what 2 Stroker's link says. From -20F to over 100F. That's perfect for this Michigan boy.
