p0237 - Ford Powerstroke Diesel Forum
Old 02-12-2012, 09:36 AM
p0237
keep throwing a p0237 code. would this be caused by the turbo needing clean? will spit, sputter and throw out some white smoke under load when cold.. turbo spools up slow and sometimes sticks. usually only does it when its the motor is on the cool side..
Old 02-12-2012, 02:13 PM
anyone????
Old 02-13-2012, 10:39 AM
bump it up
Old 02-13-2012, 10:52 AM
Fault Code - Condition Description - Probable cause
P0237 - Turbo boost sensor A circuit low input - Circuit open, short to ground, MAP sensor
This is what I found - Hope it helps point you in the right direction.
I've read if your turbo is sticking, it may need to be cleaned. Personally, I don't have experience with that - I'm sure some here would know about it though.
Old 02-13-2012, 01:25 PM
i understand what the code is.. just want to know whats causing it.. pretty sure the turbo needs cleaned. is there a sensor in the turbo that could go bad or anything?
Old 02-13-2012, 04:51 PM
Powerstroke Techie
Feedback Score: 3 reviews
P0237 is an electrical fault for the MAP sensor. It could be the sensor or related wiring
The MAP is on the right side on top of the evaporator box. it's a 3 wire sensor with a pressure hose running to the intake manifold
Old 02-13-2012, 04:53 PM
ok thats where i will start.. i just got the truck and he said it had a new map sensor in it. but i will check it out.. is there anyway to test them?
Old 02-13-2012, 05:20 PM
Powerstroke Techie
do you have a DVOM or volt meter?
