New injectors still rought start - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-12-2012, 05:58 AM Thread Starter
JimboJames's Avatar
OK I just had gotten my truck back two weeks ago from getting headgaskets and studs. They also installed a set of Warren Diesel injectors for me. The truck starts and runs like crap. So I checked the FICM and the volts never drop below 48V during start up and idle.
The shop says new injectors I got are crappy but it does not throw any codes when it scans. I had two bad injectors and 4 going out before the change. The truck starts worse than before. Any thoughts? I plan on calling Jess Warren this week if I can't figure it out.
05 F-350 lariat 4x4 crew cab SB
4" straight pipe
SCT innovative's extreme street
edge insight
leveling kit 35" Nitto terra grapplers
ARPs & EGR Delete
Warren Diesel Stock+ injectors
JimboJames is offline
post #2 of 15 Old 02-12-2012, 06:05 AM
willholl79's Avatar
Intersted in outcome. Subscribed.
2005 F-350 CC LB 4x4 XL 6.0
SCT
4" Turbo back exhaust
03 turbo
Studs
Coolant Filter
Warren Stock+ injectors
1996 F-250 ECLB 4x4 XLT 7.3 Auto
1993 F350 CCLB 4x4 5spd 7.3 NA
willholl79 is offline
post #3 of 15 Old 02-12-2012, 06:23 AM
2003kingranch's Avatar
Need to start checking fuel pressure, injector harness, FICM connections, icp ect... I don't know if I've ever heard of anyone getting a bad set if injectors from him. But anything is possible
[/URL]
[CENTER]2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #4 of 15 Old 02-12-2012, 07:01 AM Thread Starter
JimboJames's Avatar
Thanks for telling me what to check, but I have no idea how check the fuel press. I have checked the FICM connectors and they are good and tight.
4" straight pipe
edge insight
ARPs & EGR Delete
post #5 of 15 Old 02-12-2012, 07:13 AM
this isnt the cheapest route but a edge insight cs or cts with a eas fuel pressure sensor. so you can monitor everything all the time.
[/URL]
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
post #6 of 15 Old 02-12-2012, 09:20 AM
npccpartsman's Avatar
Quoted: 5 Post(s)
Also, just because the FICM voltage checks out doesn't mean the FICM isn't bad.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #7 of 15 Old 02-12-2012, 04:56 PM Thread Starter
JimboJames's Avatar
I have that seen that but what other ways are there to check the FICM. Can the original edge insight check fuel pressure? As that is what I have.
4" straight pipe
edge insight
ARPs & EGR Delete
post #8 of 15 Old 02-12-2012, 07:57 PM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
My truck is going in this week for gaskets and studs. I'll be doing the warren injectors on my own to save $$$$...I'm interested in what you find.
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #9 of 15 Old 02-13-2012, 07:12 PM
I win....
cRaZy8's Avatar
Quoted: 41 Post(s)
Garage
This sounds like we have a similar issue.
I just replaced all 8 of my injectors due to a few of them deciding to quit. I used OEM rebuilt units from Performance Machine.
I replaced the frame mounted pump at the same time (weak pump killed the injectors).
My FICM never drops below 47.5V.
When it drops below 20* over night, I get a shakey start with 3-4 seconds of "the romps". It clears up very quickly. This just started last week.
Once the engine is very warm (30+ min), I can get it to give a slight shudder/miss. This has been happening for about 6 months. I thought I fixed it once I put in the new injectors and pump. Wrong.
I still suspect my FICM is on the way out. I believe once heat soak sets in, something inside is breaking its contact due to something expanding. My FICM was replaced by the dealer about 2 years ago.
I will follow this thread as well. Please post results once you have it fixed.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
post #10 of 15 Old 02-15-2012, 01:01 PM
i am having same type issue, but want to make sure its injectors before replacing them, keep us updated on what u find out...
i hv checked fp, ficm, changed oil and filrters
teds is offline
