New to diesels smoking 6.0 powerstroke - Ford Powerstroke Diesel Forum
Old 02-07-2012, 11:39 AM
Hello all, my wife recently purchased an 04 F250 for me. Its got the 6.0 powerstroke with about 141000 on the truck. Its got some issues that I would like to know more about.
1) it sometimes lets out a little white smoke while driving, no other symptoms.
2) its got a strange vibrations or harmonic around 2000rpms no other symptoms
I plan on doing the EGR delete, and possibly head gasket and head stud replacement.
Any other recommendations?
Does anyone have a recommendation for an Arizona based company to do the work on this truck ?
Thanks
Old 02-07-2012, 11:49 AM
Don't have a 6.0L, but you're in the right forum!!
Not sure what response you'll get, but here is a link to a forum for Arizona members. Perhaps they could address the shop question.
Arizona Members - Ford Powerstroke Diesel Forum
Old 02-07-2012, 01:42 PM
Thanks
Well it looks like a bad egr cooler need to pull the egr valve and see if it is damp or wet (coolant) is the degasing tank low on coolant the full cold mark is the add mark cold. If bad must change both the egr cooler and oil cooler need gauges the ones in the dash are a joke when they move it's to late. These guys will show you how to pull the egr valve, little raw.
6.0L power stroke egr repair - YouTube
BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0 they are in Mesa, Arizona
the Edge Insight CTS a great tool, the expandable probe so if you want to add more to it down the line plus you can run 8 things at one time.
Edge Inisight CTS
Things you can add down the line like turbo timer & back up Monitor & fuel pressure
The Edge accessory system (EAS) was created with future expandability in mind Product Code: EDG98603
Edge Products – CTS UPDATE: Turbo Timer Install | Toy Hauler Adventures Product Code: EDG98604
Insight CTS Monitor by Edge Products | Toy Hauler Adventures
Ford Powerstroke 6.0L fuel pressure monitor and low pressure fix. | Toy Hauler Adventures
or you can order here Free Shipping
Diesel Performance Parts & Products | Alligator Performance
Lot of guys get the ScanGaugeII to me not as good as the Edge because you can not use the pyro a must if you pull
ScanGauge - Trip Computer + Digitial Gauges + ScanTools
2 stroker
Old 02-07-2012, 09:15 PM
x2. i highly recommend a delete if u dont have emisssions testing. if u do, bulletproof egr sounds good.
Old 02-08-2012, 07:23 AM
Thanks guys.
With the EGR delete bulletproof advises to go with their aftermarket cooler vs. a delete. Is there really any power difference or is it just a matter of personal preference?
