Please help! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-06-2012, 06:05 PM Thread Starter
Please help!
please help
Ok i had #7 injector bad the only one dealership said was bad i replaced it. Now it idles perfect but at about 1500 rpms its got a stutter no codes no weak injectors according to the computer. Has anybody had this problem Thanks jeremy
JEREMY HENDRIX
farmboy8410 is offline
post #2 of 6 Old 02-06-2012, 06:38 PM
Originally Posted by farmboy8410 View Post
please help
do the blue spring update, switch to 5w-40 synthetic oil. id also get a fuel pressure gauge mounted in the cab. low fuel pressure, which kills injectors is common in many of the 6.0s on the road. the blue spring updates that to a good number. the synthetic should clear up some sticiton if u have any. if it helps but doesnt cure it, try some rev-x.
05 F250 FX4 Supercab XLT LB 6.0 Torqshift ESOF, Boss V-Plow, Diamond plate running boards and toolbox, 105gal Diesel Tank 15GPM pump, 130+k Blue Spring Update, Sinister Coolant Filtration Scangauge 2
joe_r_dog is offline
post #3 of 6 Old 02-07-2012, 04:12 PM Thread Starter
Thanks for responding ive done the blue spring i run Rotella synthetic with Lucas synthetic oil stabilizer ill check the fuel pressure tomorrow thanks again
JEREMY HENDRIX
post #4 of 6 Old 02-07-2012, 04:16 PM
That Lucas oil treatment has caused a LOT of grief for 6.0 owners in the past. There have been reports of it causing oil foaming that leads to injector performance problems. A 6.0 uses oil to power the injectors at 500 to 3500 PSI. The ONLY additive I would use in my oil would be REV-X. Some say Hot Shot Secret is ok , but I wouldn’t use it in my truck.
HAM_RADIO_MAN is offline
post #5 of 6 Old 02-07-2012, 04:37 PM
and
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #6 of 6 Old 02-07-2012, 10:06 PM
Originally Posted by 2 stroker View Post
and
2 stroker
agree with both. lucas additive is great in semis and all those other diesels, but not in these heui powered powerstrokes.
