Thermostat Replacement - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-03-2012, 09:05 PM Thread Starter
dieselburner21's Avatar
Quoted: 8 Post(s)
I know there are a couple write ups on changing the thermostat on our trucks but I just wanted to throw some pictures of the procedure and how easy it really is, also I might have done some things differently but it all worked out great.
First is the drain pettock on the bottom of the radiator, use a 3/4" wrench/socket and drain coolant into container (I drained about 2.5 gallons which was enough)
Picture of all the crap in the way of getting to the thermostat
Next take 7mm socket to the upper rad hose (or flathead screwdriver), I used a bungie cord to keep it out of the way
Much better view and room to work around with that out of the way
Also I took one of the lines going to the degas bottle off because it was in the way, you could get away with leaving it on
Same pic as earlier but with both hoses out of the way there is enough room to get a swivel socket with a very long extension, or two medium length extensions, no pic of the socket but with the extension and swivel I did not need to remove the air intake at all (10mm socket for thermostat housing bolts)
And wala it is out, no removing the air filter or anything
Thermostat out, very dirty
And here is the new one, Part number RT-1169. It was cheaper for me to get this at my local dealer and they also had it in stock so I picked it up the next day, no shipping. Also came with new oring, the old one had pitting and looked pretty crappy
The most time consuming process was actually letting the coolant drain, overall probably took 45 minutes and this was with the draining and me running back and forth to the toolbox and so on. Overall easy project and very important, before coolant temp would not get over 170 degrees at all since its the winter. Now Im seeing 190 consistently, oil temp 196
Also along the lines of putting what you drained back in or buying new stuff. I still have ford gold in there and what I drained I put back in. I know its probably not the best but no way I was going to go out and buy more ford gold as I am going to do a chemical flush at some point in the future. As far as I know this is the second thing to go wrong with my truck, the first being the serpentine belt. 200,000 miles with ford gold, factory everything and still going
Will
2010 FORD F250 LARIAT CCSB 6.4
-H&S Mini Maxx / Edge Insight CTS / 4" Flo Pro Dump / 20" Fuel Hostages / 33" Toyo AT's / Airdog II 4G
2006 FORD F250 LARIAT CCSB 6.0 - TRADED
2000 FORD F250 LARIAT CCSB 7.3 - SOLD
dieselburner21 is offline
The Following User Says Thank You to dieselburner21 For This Useful Post:
sealeveloc (01-01-2014)
post #2 of 4 Old 02-04-2012, 07:40 AM
Yours is lil differnt than mine. 13 mm housing boots. Thought I could just use a swivel extension. Not working. On my way to buy more toys. I mean tools.
2004 F-250 Crew Cab 4x4
5" MBRP Turbo Back No Cat or Muffler
SCT X3 GearHead SRL
Edge Insight CTS
Glow shift 4 pod Gauges: Tranny, fuel pressure, EGTs, and Boost
Blue Spring Update
6.4 Banjo Bolts
Sinister Coolant Filter
AFE Stage II Cold Air Intake
More to come is
Studs, Oil Cooler, EGR delete, Coolant Filter, Air Dog, bigger injectors, and Water/Meth Injection
demott930 is offline
post #3 of 4 Old 02-04-2012, 01:34 PM Thread Starter
Quoted: 8 Post(s)
Guess they changed in 05-07? Mines and 06
Will
post #4 of 4 Old 02-27-2015, 04:23 PM
Did yours make a rattiling noise
Psdman is offline
