Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 06-28-2006, 04:17 PM
diesel operator diesel operator is offline
Exclamation 06 missing bad,over fueling
Any one heard of intake problems on any of the 6.0s? I was in town this morning,stopped at a light and my truck started missing very bad and over fueling. tons of unburnt fuel bellowing out of the pipe. Limped it to the local ford store. Anyway, the service writer is telling me it sucked the intake gaskets in because of the aftermarket aircleaner! Makes no sense to me. Any quesses so I will have some response to the dealer ? Thanks only 4500 miles 500 since tuner installed Oh also the engine light did not come on if that helps
Old 06-28-2006, 06:51 PM
mschn99 mschn99 is offline
WWWHHHHOOOOAAAA....those intake gaskets are plastic with rubber linings, and i have seen aftermarket air boxes cause problems, but it wouldnt cause this IMO.......sounds to me like a cut and dry bad injector or maybe even more than one..... i would reccomend taking that truck to another dealer if there is one close. DONT drive it, you could end up with a runaway if its dropping htat much fuel..........Marc
Old 06-28-2006, 07:16 PM
Well, The info I wrote came from the service writer and not the diesel tech the tech is at school till Friday. I work on diesel heavy equip. AND i was under the same impression way too much fuel dumped in the cylinders for the pcm to be doing to compensate for an intake gasket. Do you think the pcm going into a defalt would pour that much fuel? This thing has got my gut tied up Cant take it one someone else has to fix things!!! Thanks for differnt things to ponder. just put in the economy mode from sct was on performance now back to stock but still dumping buckets of fuel Im sure the cylinders got washed down also. Now Im babling I want my truck home! HA HA
Old 06-28-2006, 07:21 PM
since diesel is closer to oil than gas, the cylenders dont get washed down like a gas motor....but i have a feeling that your intake gaskets are fine. i would bet on it you have one or more bad injectors. it needs to have a power balance done when the cylenders act up.......Marc
Old 06-28-2006, 07:33 PM
I am heading back to the dealer tomorrow to take the stock a/c to them I will say something along the lines of injectors dont want to p these guys off buy telling em how to do the job would a injector being stuck give a code on this new stuff? I deal with mechanical injectors .
Old 06-28-2006, 07:36 PM
these injectors are electric over hydrolic. If a mechanical part fails, it will not set a code if hte electrical part is working properly.......it could be internal injector failure or an o ring failure and not set a code. if an electrical part fails, then you would get a code........Marc
Old 06-28-2006, 07:46 PM
Oh I forgot to complement you on your truck nice chevy I have got a 46 GMC sitting in my shed waiting fir attention if I can get my kid to tell my how to put pixs on here I will get some just got a new camera too many buttons for smashed fingers
Old 06-28-2006, 07:49 PM
thanks man....i actually sold that truck last january.....gonna do another one though....the next one will be even better!!!
Old 06-28-2006, 07:50 PM
Ok Marc nice talikng to ya got some other things to fiqure out to eleminate all the variables I really beleive it is an injector problem also now that I got to talk about it. Have a great night Thanks again for the information I will let you know what the ford store thinks about it LATER DUDE Brett
Old 06-28-2006, 07:55 PM
My 46 was actually my grandfathers first new truck used it on his farm, If I can beef up the frame enough it will get a PSD motor and trans, bet that will get the street rodders attention!! OK gotta go Work comes early in the morn..
