Power loss - Ford Powerstroke Diesel Forum
Old 09-11-2007, 03:38 PM
Power loss
On some mornings when I first start my truck, it will not rev higher that about 1100 rpm's. It does not do this on all mornings and temps have been in the 60's to 70's. After it warms up for about 5 minutes, it runs just fine. During this time, it will move on level surface but will not pull an incline. it slowly improves over about 5 minutes. Any ideas?
My truck is an '03 F350, 6.0L 4X4 CC DRW with auto transmission. 91K miles.
Old 09-11-2007, 03:44 PM
sounds like you dont have enough high preasure oil to fire the injectors
Old 09-11-2007, 04:10 PM
Would this be an intermitent problem? Only happens occasionally.
Old 09-11-2007, 04:12 PM
Desert Shield/Storm Vet
See if you have any codes stored.
Old 09-11-2007, 04:13 PM
it could be the vanes in the turbo stuck but I would think that you would be able to rev in nuetral... it could be the injector preasure regulator sticking
Old 09-11-2007, 04:15 PM
I can rev in neutral, but slowly.
Old 09-12-2007, 03:24 PM
bump bump bump
Old 09-14-2007, 02:46 PM
Took it to the shop. They ckecked it out. Ford had a new program and they reflashed it. Runs better than ever. I hope this is it.
