Sudden loss of power - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 132 Old 01-07-2012, 04:09 PM Thread Starter
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
2003 6.0 all of the sudden i have lost power going up grades and passing power, Inter cooler boots seem ok, truck shifts ok and runs 65 down the road no problem, No check engine light but when i hook up scanner i have DTC p2290, will this put the truck into a limpmode condition
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #2 of 132 Old 01-07-2012, 06:04 PM Thread Starter
roche837's Avatar
Quoted: 5 Post(s)
Garage
well.... i guess ill clear the dtc and try it UPDATE: DTC p2290 returned
roche837 is offline
post #3 of 132 Old 01-07-2012, 07:01 PM Thread Starter
roche837's Avatar
Quoted: 5 Post(s)
Garage
anyone had any similar issues?
roche837 is offline
post #4 of 132 Old 01-07-2012, 08:15 PM Thread Starter
roche837's Avatar
Quoted: 5 Post(s)
Garage
So after clearing the dtc's the truck still hesitates under full acceleration, any help would be appreciated, the truck doesnt miss or smoke just doesnt seem to not kick down when you lay into it, turbo seems to spool ok, at a loss.
UPDATE: Just removed and cleaned EGR valve, it was pretty clogged up, I hope it was the problem i will update later. (NOT THE PROBLEM)
roche837 is offline
post #5 of 132 Old 01-08-2012, 12:50 AM Thread Starter
roche837's Avatar
Quoted: 5 Post(s)
Garage
Seemed to be a little bit better with a cleaned EGR valve, (Only drove it briefly but overall no change)
Trying it completely disconnected on the trip home. Update results later.
I feel like im talking to myself!
roche837 is offline
post #6 of 132 Old 01-08-2012, 01:46 PM Thread Starter
roche837's Avatar
Quoted: 5 Post(s)
Garage
UPDATE: Cleaned EGR with no change, Then half way home i Unplugged it with no change.
Will have FICM Tested.
roche837 is offline
post #7 of 132 Old 01-09-2012, 05:56 AM
mdub707's Avatar
Test that FICM yourself. I can repair it if need be. I'm not sure that's your issue.
Are you getting any smoke out the exhaust when this is happening? Truck making any funny noises, or just starts losing power? Only on hills?
DamnKids Motorsports
2006 F-250 6.0 4x4
Innovative Diesel Tuning 466/772 7/19/08
VEGISTROKED
mdub707 is offline
post #8 of 132 Old 01-09-2012, 04:15 PM Thread Starter
roche837's Avatar
Quoted: 5 Post(s)
Garage
FICM was rebuilt last winter, no smoke at all, turbo fart under hard acceleration, engine does not stumble, miss, skip, just has no power when you lay into it.
Im suspecting a leaking turbo boot. I know its not the EGR because i cleaned and unplugged it with no change, I know its not the VGT stuck because with my SP exhaust i can hear it being cycled by the PCM.
This leaves a boost leak or something with an injector?, I just ordered some VPMAX inter-cooler boots. mine look pretty ragged but Ive been working all this weekend and haven't had time to pull them off yet. (DO NOT BUY VP MAX BOOTS HAD NOTHING BUT PROBLEMS WITH THEM!!!!)
roche837 is offline
post #9 of 132 Old 01-09-2012, 06:41 PM
mdub707's Avatar
If it was from a lack of air flow you'd know it, it wouldn't be farting non stop. Have you checked or cleaned your EPB sensor at all? I'd remove the tube and sensor and clean both. Inspect the wiring going to that sensor as well. It is on the drivers side exhaust manifold.
2006 F-250 6.0 4x4
VEGISTROKED
mdub707 is offline
post #10 of 132 Old 01-09-2012, 06:48 PM Thread Starter
roche837's Avatar
Quoted: 5 Post(s)
Garage
It doesnt fart until i mash the pedal and release quickly(which is normal from my experience), i have not checked the EPB sensor i will seeing how i have to remove the intake and what not to do the intercooler boots, Just read a write up on the procedure.
Thanks for the insight though your the only person who has suggested anything. Leave it to a fellow ESS.
roche837 is offline
