2004 F350 water in fuel light comming on. - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-08-2011, 08:36 AM Thread Starter
When driving down the road the truck will stall the water in gas light will come on along with the glow plug light and the truck will then restart. It does this sometimes when taking off also. I am ussing fuel additive for gelling and water, which makes a huge difference in the way the truck runs. I have had the truck for about 2 months didn't do this in the begging, I have changed the fuel and water separator filers.
ToddShroats is offline
post #2 of 13 Old 12-08-2011, 11:06 PM
Any codes? What did the fuel filters look like when you pulled them out?
HAM_RADIO_MAN is offline
post #3 of 13 Old 12-08-2011, 11:23 PM
When you changed the fuel filters did you use Ford filters, i hope.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #4 of 13 Old 12-09-2011, 06:40 AM Thread Starter
I didn't use ford filters, and they looked OK. I have been reading and have found the drain plug on the side of the water separator. I tried to drain it and the plug striped out. I did buy a motorcraft oil filter for when I change the oil and I plan to replace the fuel filters with motor craft the next time around.
post #5 of 13 Old 12-09-2011, 08:04 AM
cdelap's Avatar
A work truck that I had but in 05 had a valve where the drain plug was which made it real easy to drain any water off. Has anyone seen this, did the mechanic add it to make maintenance easier? I was up in the UP this summer and had a bout with some water in the fuel and was having to pull over every 100 miles or so and drain it through the majority of 2 tanks.
I swore I would ask when I got back but forget till I read this post.
Canton Michigan
2007 F350 Crewcab Longbed
Mods: Racing Evolution CTS, EGR Delete, Oil Cooler replacment, Sinister Coolant Filter
cdelap is offline
post #6 of 13 Old 12-09-2011, 11:55 AM
By the time you get to the next time you may need 8 injectors ONLY Ford or Racor fuel filters will help keep the water out of the fuel filter before it get to the injectors they have the water rap around the filter.
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
post #7 of 13 Old 04-13-2014, 04:37 PM
Having the same problem and I just paid a mechanic $550 dollars to put a new water in fuel manifold on there. It cant be that. There has to be something else causing it. Mine only does it when I hit a bump or pot hole in the road. Any held would be great.
bigk33 is offline
post #8 of 13 Old 04-14-2014, 04:58 AM Thread Starter
What I figured out to be the problem was the plugs going into my FICM. The injector computer unit is on top of the drivers side intake and the plugs on the bottom break and wont stay in the unit. Being on the bottom they stay in until you hit a bump or torque the engine. The easiest fix is to put a rubber hose such as a heater hose under the plugs before you remount the FICM, this will keep them in place and fix the problem.
I also tried to fix the fuel pump with the upgraded wiring and replacement cover, plus the new larger drain plug. This had no affect on the problem and seemed not to make any difference in the way the truck ran. Plus after two years of haveing the new water separator plug the new one wont unscrew either.
post #9 of 13 Old 04-14-2014, 05:15 AM
Thanks bud I'm going to try that this afternoon.
bigk33 is offline
post #10 of 13 Old 04-24-2014, 06:23 PM
Just to let you guys know what Todd Shroats said above works if your having both the glow plug light and wif light come on after hitting a bump. Thanks Todd
bigk33 is offline
