Y pipe question - Ford Powerstroke Diesel Forum
post #1 of 15 Old 12-08-2011, 05:51 AM Thread Starter
brndfrb's Avatar
Y pipe question
My diesel mechanic told me that my Y pipe on my 6.0l is cracked. If you really rev the motor with the hood open exhaust comes out of the engine compartment. And i get lots of fumes in the cab. Can you see this pipe from under the hood? Also is there any way to repare the pipe instead of replacing it?? Any help would be great
brndfrb is offline
post #2 of 15 Old 12-08-2011, 05:57 AM
dieselflash's Avatar
its the upipe that feeds the turbo, it hooks to the back of the turbo,its the smaller pipe not the downpipe, it has expansion joints that look like bellows wrapped in a wire mesh that crack and leak no way to fix them, you just have to replace it, i think there are some aftermarket companies that make a solid pipe with no expansion joint
Ford Master Diesel Tech
dieselflash is offline
post #3 of 15 Old 12-08-2011, 05:59 AM
Term3's Avatar
Quoted: 2 Post(s)
It is more likely that one of the bellows is cracked. If that's the case Elite sells a Y pipe with heavy duty bellows.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 15 Old 12-08-2011, 06:00 AM Thread Starter
brndfrb's Avatar
can you see this pipe without removing anything?? Any idea what that thing costs?
brndfrb is offline
post #5 of 15 Old 12-08-2011, 06:11 AM
u can kinda see them a little bit from the bottom side but its really tight
post #6 of 15 Old 12-08-2011, 06:18 AM Thread Starter
brndfrb's Avatar
ok, Well i guess i am going to have to bight the bullet and have it replaced UGH
brndfrb is offline
post #7 of 15 Old 12-08-2011, 06:20 AM
Term3's Avatar
Quoted: 2 Post(s)
You would only see one side of them. Just crawl under your truck with a flashlight and check if you can see soot on the outside of all three bellows. As for price just check out Elite Engineering web site.
Term3 is offline
post #8 of 15 Old 12-08-2011, 09:19 AM Thread Starter
brndfrb's Avatar
oh i have lots of soot in the engine compartment
brndfrb is offline
post #9 of 15 Old 12-08-2011, 09:22 AM
APEXER's Avatar
y pipes
I put the one on from liberator diesel. also have an EGR delete and used the long y pipe kit they sell. worked great and don't worry about the bellows now.
I changed mine when i did the studs. all I recommend is get new bolts save ya a bunch of grief when putting it back together.
2003 F350 CC, SB, KR. Bushwacker Pocket flares, 06 engine. EGR delete. ARPs. SCT livewire GH tunes, Liberator Y pipe ,airaid cold air, Banks TechniCooler, 03 Turbo W/BATMOWHEEL, magnaflow turbo back straight pipe, single 4" with 5 inch tip, STC fitting, Sinister Coolant Filter, ELC coolant, Pure power Oil fuel filters, 6.4 banjos, 4 inch procomp, 22x10 ultra chrome 247 lightings, 325 50 R22 Nitto Trail Grappler M/Ts
APEXER is offline
post #10 of 15 Old 12-08-2011, 09:47 AM Thread Starter
brndfrb's Avatar
Did you do the studs as a preventative measure or did you blow a head gasket?.
brndfrb is offline
