my truck goes into ford tuesday if i program it and run it tuned until monday and then put it back to stock and disconnect the battery before i take it there will they be able to tell it was programmed? techs please reply..thanks
I think that will work. I'm not a tech, but I did stay at a Holiday Inn Express last night. Some one will be along to help you out soon. Good Luck. IMO I wold leave it stock until it came back from the shop.
Thats a good one! If u stayed there you must know what your talking about...Ive kept it stock since i recieved my custom sct and ford still isnt sure whats wrong either injector issue or they said my k&N is letting to much dust in and is causing low compression and will need a new block....sounds a lil fishy to me.....we'll see what they say after the compression test....btw im only getting about 8 to 9 mpg!!! thats y i want to load the economy tune and wait until i get it fixed to go looney....guess ill wait unless someone replys that knows for sure....
that would be the best thing IMO. Just sit and wait for someone that knows. But I'm almost thinkiing that most of them are at DITD. Lucky dogs.
The way im looking at it is either way there gonna have to tear down the motor and if not covered by warranty i see some studs and injectors coming my way....
I take my programmer off in the parking lot of the fleet center and then hide it under the middle seat.
