Ball Joints - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-29-2007, 02:11 PM Thread Starter
Ball Joints
I had all my ball joints replaced on my truck 1 year and 1 month ago. I take my truck into ford to have a recall done and they tell me that I have bad ball joints. I thought they were trying to screw me especially when they told me I had to replace my fuel filters for $140 when I changed them myself for $30 last week. Took it too a good shop and sure enough the upper left ball joint was bad. I saw it for myself. Has any one else had this much trouble with the ball joints on their truck????
Thanks,
Nick
2003 F-350 6.0 PSD Crew Cab FX4
3.5 Fabtech Lift
Fabtech Dual front Shocks
Fabtech Dual Steering Stabilizer
Fabtech Desert Guard
20x10 American Racing Mojave Beadlock
35x13 Nitto Terra Grappler
Silverline 4" Turbo Back
MagnaFlow Race Series Muffler
Edge Juice Platinum
Volant Ram Air Intake
TAG
nss8425 is offline
post #2 of 6 Old 08-29-2007, 04:26 PM
Lonno's Avatar
What degree cams you got on there? If they put 2 degree or more on with your lift that might cause early wear.
1970 F250 Crew Cab rebuilt/restored w/Cummin s 4bt
8v, M5R2 Tranny, VE pump, DennyT stage 2 pin, M&H Dynamic Timing, 3200k gov spring, Hx30/Hx35 Twins, 40hp styx, smoke screw screwed, star wheel cranked, Hydroboosted
91 Gillig Phantom, Converted transit bus, 6v92 Detroit Diesel
6500 Watt Diesel Generator on board
All Diesel
All Day
Lonno is offline
post #3 of 6 Old 08-30-2007, 04:37 AM Thread Starter
I just used a drop and hanger lift which just lowers the axel straight down.
3.5 Fabtech Lift
Edge Juice Platinum
TAG
nss8425 is offline
post #4 of 6 Old 09-04-2007, 11:39 AM
WOOL-PULLER's Avatar
my joints got replaced at 50kmiles.
thought that was pretty good since i run big 22.5 wheels/tires.
WOOL-PULLER is offline
post #5 of 6 Old 09-04-2007, 11:57 AM
Jon
Guest
Posts: n/a
Quoted: Post(s)
Ball Joints
super duty ball joints are bad for going out around 75 to 100,000 miles. However. I have seen many lifted super duties with bigger then stock tires go through them in 20 to 40,000 and one as low as 8,000 miles. So take that into consideration.
post #6 of 6 Old 09-04-2007, 04:29 PM
SMKSTAX's Avatar
Heck my 04 is totally stock and I had my ball joints go at 60,000.
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
