06 f250 6.0 white smoke - Ford Powerstroke Diesel Forum
Old 08-26-2007, 01:27 PM
Exclamation 06 f250 6.0 white smoke
Hi everyone,
I am new to the forum and need help!!! i have a 06 f250 cc,sb with the 6.0 with 36,000 miles and it pours white smoke out the exhaust once it is warmed up, its at idle when in park, and when im at stop lights and taking off. I took it into ford and they said there was gas in my fuel tank and it should quit once it all ran through the motor and 3 weeks later still doing the same thing... i know i didnt put gas in because the diesel pumps are complety seperate from the gas where i live at..any advice would be greatly appreciated...thank you....
btw...4 inch straight pipe no kitty or muff into 5 inch stack, k&n fipkII intake,and just ordered sct xcall2 from vivian at dj's and cant wait to get it!
Old 08-26-2007, 01:40 PM
Keep an eye on your coolant, and on your oil. To see if the coolant level is going down or the could have oil in your coolant.
Could be an egr cooler or egr related problem. Worse case senario a head gasket.
The stealerships love to lie to people about their trucks problems.
Welcome the the ORG!!!!
Brandon
Old 08-26-2007, 01:49 PM
Sounds like a possible head gasket which would explain coolant loss and or oil mixing with it. Warranty should cover it though.
Old 08-26-2007, 01:53 PM
Dude take it back and tell them to fix it right! Dont let them give you any BS. You are under the 36k and 100k warranties.
Old 08-26-2007, 01:56 PM
Originally Posted by 06F-250-6.0 View Post
Hi everyone,
Definatley egr or gaskets!!! But more than likley egr cooler
Old 08-26-2007, 01:57 PM
Exclamation
head gasket is good, oil level good, coolant level good, they said egr was good. I appreciate the replys and will keep everyone posted when we get this figured out...what are your thoughts on some jackass pouring oil or something down my stack...btw love the org very helpfull...
Old 08-26-2007, 02:05 PM
could be water sitting in the exhaust if there isn't a drain hole for the water to come out of it.
Old 08-27-2007, 07:14 AM
Its a bad turbo... Mine did the same thing about 2 months ago. Ive already been through two of these POS stock turbos, so Im planning on getting a BD next time!
Old 08-27-2007, 07:18 AM
Desert Shield/Storm Vet
Yeah what they said but don't take it back to that dealer
Old 08-27-2007, 08:49 AM
i have the same problem it only does it when its cold. like when i start it up in the morning
