Need help...Overheating!! - Ford Powerstroke Diesel Forum
Old 09-18-2011, 12:39 PM
Today I looked down to see my temp almost in the red. When I push on the gas there is a big gush of air which I think is just the fan spinning faster when it the motor spins faster. When I turn the heat on the A/C is on and it blows cold air. All of my coolant is still there also I didnt notice at first but the degas bottle is FULL. Tried to pull the cap of to see if it was circulating and a couple turns in to it, it started coming out.
I hope this is just something like the thermostat sticking. Anyone have any ideas?
Old 09-18-2011, 01:39 PM
Your on the right track to start with. First put in a new stat, I think I remember that these were suppose to fail open, not sure? Second, the plastic impeller could have come off the water pump. Hope you didn’t blow a head gasket or EGR cooler. GOOD LUCK
Old 09-18-2011, 02:06 PM
yea I dont have a egr cooler Hopefully not headgaskets...coolant didnt come out due to puking but I think the coolant just doesnt have anywhere to go since the tstat might not be opening? Not sure...waiting on everything to cool down to start looking into it
Old 09-19-2011, 08:53 AM
Any ideas anyone? Its raining now so cant look into it yet
Old 09-21-2011, 04:28 PM
Anyone have any input? Lookin for some before I go diggin in
Old 09-26-2011, 04:21 PM
TStat seems ok. Put it into boiling water and it opens up. Something else I noticed is that during warm up it will blow normal air but once it warms up and I turn the heat on it will blow cold air. The a/c compressor also comes on after it warms up and I turn the heat on.
Anyone have any ideas where to look next or how I can test other things like the heater core or water pump. I hope its not the water pump as I replaced it when I got headstuds done. Any input would be appreciated!
