Please help me, I'm an idiot - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-18-2011, 09:28 AM Thread Starter
Hey all, I'm new to this forum, but I've been watching and reading for about two months now. I have a 2004 PSD F350. Last night, I got the bright idea to clean the egr valve after changing my oil and fuel filters. So I followed all the steps that I have seen on youtube and read here. After putting it back in, it started up, then shut down. Then I restarted it, and it idled hard for a second then ran just fine. The only problem is when I rev it or drive it. If I press the pedal, it sputters for a second with a lot of smoke and no power, then it picks up and goes like it always has. I tried unplugging the egr valve but no change. Any ideas would be great, thank a lot!
StrokinWarmblood is offline
post #2 of 3 Old 09-18-2011, 09:57 AM
Chapter Director
psd_va's Avatar
I'd check to see of the gasket or either of the orings got messed up
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #3 of 3 Old 09-18-2011, 01:46 PM
You did a lot of work at once and this problem could be related to anything you did.
Check the o-rings on the EGR valve.
Did you use OEM filters and do they have OEM caps on them. YES, this is a big deal on a 6.0
You may have air in the fuel system, the fuel filter cap may be cross threaded or just loose enough that it is sucking air in. I have seen this at the filter under the truck sometimes.
HAM_RADIO_MAN is offline
Tags
6.0 , egr , no power , smoke , valve
