Could a bad turbo cause surging driving up hill? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-10-2011, 05:40 AM Thread Starter
Kwattro's Avatar
I've been having a surging problem with my '06. It bucks going up hills and is worse with higher loads. I can't "see" anything wrong on my Auto Enginuity, all specs look normal, but I have been noticing some oil haze at idle and the turbo makes a grinding/spinning sound on shut down that echos all the way to my tailpipe. Has anyone had this issue solved with a new turbo? or even solved it with any other repairs?
The El Cheapo Cooling Filtration DIY - It works!
_________________________________________________
-= 2006 F-350 SuperCrew 4x4 6.0L PSD =-
IIS Stage 1 Turbo, Warren Diesel 155cc/0% Injectors,
Swamps 58v FICM, PHP Atlas 40 Tune, PHP Gryphon Programmer,
5" Diamond Eye Exhaust, DieselSite Coolant Filter,
Knockoff EGR Delete, ARP studs, 33" Toyo MT's
Kwattro is offline
post #2 of 8 Old 09-10-2011, 06:15 AM
Sunday's Avatar
I'm curious to see what is said about this. Mine just started surging about two weeks ago. I'm not getting any haze or grinding noise though, the rpm's just jump up and down when I'm pulling a hill or have a heavy load like your experiencing. My truck doesn't do it if your running it hard though, it just seems to be when I'm at a constant speed.
Sunday is offline
post #3 of 8 Old 09-10-2011, 06:28 AM Thread Starter
Kwattro's Avatar
Yes, mine's a constant speed problem too. Already pulled and cleaned the EGR and put in new gaskets. Then I unplugged it and that changed nothing. IPR, IPC, all that appear good on my Auto Enginuity. Almost thinking it's trans related. But since I know the turbo is pretty well shot I'm curious if that could be it.
Kwattro is offline
post #4 of 8 Old 09-10-2011, 07:21 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
are you overboosting?
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 8 Old 09-10-2011, 03:19 PM Thread Starter
Kwattro's Avatar
Nope, not at all. Almost suspecting the trans.
Kwattro is offline
post #6 of 8 Old 09-10-2011, 09:47 PM
mine has been doing the same thing, its been to ford a few times and they can't seem to figure out what is wrong either. I would like to know if someone finds a cure for this symptom so at least I know another place i could possibly look.
jerryscott is offline
post #7 of 8 Old 09-23-2011, 12:39 PM
The most common cause of this symptom is the EGR valve for those who are curious.
You've cleaned yours up so I'm not really sure where to go from there.
2005 F-350 King Ranch CCSB 6.0L. 4x4
Functional-Rotella T-6 5w-40, Ford 135amp alternator and a new pair of Interstate Megatron Batteries275/70/18 BFG AT's.
Rockwood Roo 19 Hybrid travel trailer.
Rv comfort and sleeping under canvas!
EPFD217 is offline
post #8 of 8 Old 09-23-2011, 12:45 PM
atvrider93's Avatar
Quoted: 8 Post(s)
try giving the vanes a workout with some WOT runs. open it up and look at the wheel
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
