Fuel Gauge - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-06-2011, 07:40 AM Thread Starter
Fuel Gauge
Wanted to get ya'lls opinion on this. I did a search but really did not come up with a good answer.
My Fiance just called me and said the truck is reading empty on the gauge. I know for a fact it had 3/4 tank this morning. Said she got to the gym turned the truck off then turned the key back on and the fuel gauge went up to 3/4 but then fell back down after a min to "E".
What can be causing this???
I was reading about a bad sending unit but it really did not fit the description. I normally run Diesel Kleen in every tank but have not for the last 3 tanks because I keep forgetting to pick some up.
Any help would be appreciated thanks.
2006 F-250 PS CCSB King Ranch
6" Fabtech Lift
Bilstein 5100's
35" Falken Rocky Mountain AT/S on 20" Pro Comps
EGR Delete - Performance Machine mfg.
Updated Oil Cooler
6.4 Banjo's
Updated Larger Turbo Oil Drain Tube and Feed line
"Blue Spring"
AFE Stage 2
SCT Livewire - "Looney Tune"
4" Turbo Back Straight Pipe
Updated Dummy Plugs & Stand Pipes
Roll-N-Lock Bed Cover
Train Horn (get off your cell phone horn)
Zoodad
more to come as the hours go by...
TheOne is offline
post #2 of 3 Old 09-06-2011, 07:44 AM
Wicked6.0's Avatar
Mine does it too every now and then I just deal with it cause after it uses more fuel it starts reading correctly again. It sucks but till I find a fix it is going to stay like that.
Sent from my DROIDX using AutoGuide App
2005 F250 Lariat Ex Cab long bed 6.0 diesel. 4" Turbo back exhaust, Edge Insight CTS, High idle mod to upfitter, Blue spring, 6.4 Banjo Bolts, Coolant filter, Egr Delete, STC fitting upgrade, New oil cooler (9-5-11)
Wicked6.0 is offline
post #3 of 3 Old 09-08-2011, 05:06 AM Thread Starter
I put some diesel Kleen in my tank with some fuel and also cleared the codes with my livewire. Everything seems to be fine, going to monitor the milage and make sure the gauge is working correctly
6" Fabtech Lift
Bilstein 5100's
Updated Oil Cooler
6.4 Banjo's
"Blue Spring"
AFE Stage 2
Zoodad
TheOne is offline
