FML i need help
ok i was driving my truck and it just lost power. last time it happened it was a clogged line i think. i diconnected the lines and blew air thru them and it worked right after. i just looked at the upper fuel bowl and its gettting fuel. it revs up when i turn the key like it is about to turn over but its right at the point that it wont turn over. i got it to turn over and it reved really high and then shut off!!!!
what can i do? i need my truck for work in the morning!! |
Do you have a way to check diagnostic trouble codes? Where are you located?
whats the status on this? This sounds like the tank is delamanating.
If the "line" (guessing fuel) got clogged, you need to change both filters.
