Problem with EGR Delete Kit install seeking advice.
I have a 2006 F350 with 167K . I installed Sinister's complete EGR Delete Kit, and rebuilt the oil cooler. I am not an experienced mechanic, but I took my time with it (2 days) and got everything back together, at least I think I did, the way its meant to be.
Truck starts ok, but I am not getting any turbo boost at all and the there is a steady stream of white smoke coming out of the exhaust that is definitely damp. Truck ran fine prior to me performing the delete, except for the fact that it was burning a gallon of coolant every week. I have obviously made an error during the install of the delete kit, and due to my lack of experience I could use guidance on where to start looking for the problem. Kind regards, |
I am having the same problem I just installed a egr delete on
A 03 6.0 runs fine at an idle but when u get on the throttle it blows white smoke and sputters and is low on boost. There is no Smoke at idle, don't know if it's head gasket or what any suggestions? |
The heads have to come off, find a qualified machine shop to check them over and check for flat/straight. If they must mill the surface, they can not exceed 0.008" or the head must be replaced. DO NOT assume that whatever shop or dealership you bring your truck to will do this for you. YOU get it done. If you (or they) skip this step, plan on replacing the head gaskets in a year or so when they fail again. (The FORD procedure for this step is not sufficient, don't assume that it is) Use the FORD head gaskets. Don't buy the hype on the "black onyx" head gaskets. If you do any research on the forums, you will see that the black onyx gaskets are failing quite a bit more often than the stock ones. Install ARP studs, and nothing else. The stock head bolts (no matter what some ill-informed service advisor may say) suck, period, end of story. Check the first link in my signature line. It has a bunch of info that you should know, albeit a little late for you, but it will help in the future. |
If you have not replaced the EGR cooler AND the oil cooler recently, do it. Don't drive the truck anymore. Park it until you do the repair or risk your head gaskets. |
oh great news!!! turbo is not kicking in at all. took it for a test drive and i could not even get up a small hill. White smoke is gone, but a decent amount of oil was spat out of the tailpipe.
Still think the headgaskets are shot? Thanks for the feedback Last edited by fordfenix; 09-05-2011 at 09:33 AM. |
check for intake hoses not tightened, all the way from turbo to intake manifold. if it was the head gasket or egr cooler i would expect it to smoke at idle as well, although my personal experience with this problem is fortunately limited. to some degree it could be coolant that was already in the system or some plug that did not get fully plugged back in. while HG's are a real possibility always check the small, simple inexpensive things first
Turbo cleaning PDF file attached. EDIT: The turbo is controlled by the PCM (of course), but the PCM uses a few sensors to do that. One is the MAP sensor. It is located on top of the HVAC box on the passenger side. Check the hose for cracking. Check the brass nipple on the intake for clogging (stick an allen wrench down the hole, or something that can not be dropped in). The EP sensor. Depending on your year of engine, this sensor sits in one of two spots. It is either located at the thermostat housing or on the drivers side, under the degas bottle, attached to the valve cover along with the front FICM bracket. Using two wrenches, remove the sensor (one on the sensor one on the tube it sits on). Clean the sensor, take a long piece of tie-wire and stick it down the tube or spray brake cleaner down the tube. You can't hurt the tube (unless you twist it upon removing or replacing the sensor). The tube just goes to the exhaust manifold on the drivers side. Just make sure the passage is clear. DON'T use brake cleaner on the sensor, use carb cleaner. Make sure your MAF sensor is plugged in (if present). It is on the air intake tube just after the turbo. Last edited by NYC F-350; 09-05-2011 at 01:21 PM. |
thanks for the help
will give that a go today. going to run compression test to check heads as well
compression came back with positive results/ small leak head gaskets will need to be replaced at some point,
So how hard was the Sinister kit to put in? I'm planning on buying one of those.
