IPR Issues ??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-15-2011, 11:53 AM Thread Starter
IPR Issues ???
Upon slowing down / deceleration truck engine stalls and surges with rpms kinda like have a mind of their own untill back on throttle then it hesitates at first before clearing up ...as soon as throttle is backed of again it does the same crap again ....you can tell injectors are misfiring when it drops down at its idle sequence while coasting down highway under NO Throttle
on a friends truck we just did EGR Delete & New oil cooler ...he did some kind of screen kit in the IPR while it was apart...think we should have just left it alone ??
'05 F250SD > Ranch Hand HD Bumper w/skid plate & KC's, 2.5" Leveling Kit, Firestone Rear Bags, 305/17 Goodyear Wranglers, Hide-a-Ball Hitch, SCTx3 by Vivian , EGR Delete, 4" open exhaust , 6.4 Banjo Bolts , Fuel Reg. upgrade kit , cold air intake by me , '03 Turbo by HPTurbochargers,46 gal.aux.tank, ARP Studs / Factory Gaskets.
Rmorgan711 is offline
post #2 of 6 Old 08-15-2011, 06:18 PM
Powerstroke Techie
justinmix's Avatar
I think it got crud down in the high pressure oil reservoir that has now made it's way to the IPR. Pull the IPR and check the screen. I'd put money on it that the screen is going to have a bunch of crud in it. Since it's still running you can try and replace the screen again. If you keep running it like this it's only a matter of time before the crud pushes thru the screen and gets in the IPR, then you will have to replace it.
justinmix is offline
post #3 of 6 Old 08-16-2011, 07:13 AM Thread Starter
Thanks Justin ,
Just an update , we were going to pull the IPR today at work . He pulls up this mourning and tells me its running GREAT ! damn thing is purring like a kitten now ?? so I told him if it acts up again ?? IPR is coming out anyways ..
post #4 of 6 Old 08-16-2011, 07:16 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Take it out anyway and inspect it. The junk might just be moving to a different part of the screen after you shut it off. It will just move back into a spot that will make it run like crap later.
Please
You could save the life of a sick child
NYC F-350 is offline
post #5 of 6 Old 08-16-2011, 08:24 AM Thread Starter
NYC F-350
He's looking at buying another IPR and just replacing it....I showed him the other thread where you commented on the IPR Trouble...convinced him it was cheap insurance just to replace it and be done with it
post #6 of 6 Old 08-16-2011, 08:30 AM
NYC F-350's Avatar
Quoted: 51 Post(s)
That is an even better plan!
Please
