I used a parts washer I have out in my buddies garage and left it on overnight flowing through one side, then did the same on the other. Then it was on to the scrubbing using a "bottle brush" and carb cleaner, and then I was off to the self service car wash and used the hot water/pressure to clean it up.
You could also run it over to a machine shop and ask them to "hot tank" it for you. As an edit: I do have to congratulate you for having the dirtiest Intake Manifold I have seen. ![]() As far as the ports to the cylinders on the heads, I didn't touch those. I didn't want anything falling down in there. I actually recommend you put something over them, now. Even if it is only duct tape to cover those up. You REALLY don't want anything going down in there. SERIOUS engine damage could occur. Last edited by NYC F-350; 08-12-2011 at 02:45 PM. Reason: additional info |
Thx...will definitely cover them......
I like the hot tank. The dealership I trust with our fleet said they take the 6.0 intake manifolds and just steam pressure clean them and then air dry.
Good idea about the pressure washer at the car wash! |
Heres a great product i swear by-BG throttle body and intake cleaner. Its expensive per can but worth its weight in gold! it will liquify the carbon literally melt it and you can wipe it away with a cloth. When its thick like that i use a Detroit injector brush or bottle brush and scrub the big crap off first then spray it. quickest way is to hot tank everything. |
