I'M STUMPED WHAT DO YOU THINK - Ford Powerstroke Diesel Forum
Old 08-10-2011, 05:50 AM
I have been on here alot lately as i have done a wack of work to my truck from the head gaskets to the complete high pressure oil system and i mean new hpop, stand tubes, icp sensor and ipr valve. The truck runs amazing just the only problem that i have now is when you go put the truck into drive or reverse it has a bit of a hesitation. Put a code reader on it and no codes where found. any ideas what could be causing this????
Old 08-11-2011, 03:51 PM
could be an issue with your transmission... I had semi-similar issues and it turned out to be a faulty o-ring in the tranny...
Old 08-12-2011, 09:57 AM
Im having the exact same problem but havent been able to find any answers or leads..
Old 08-12-2011, 12:10 PM
had same issue a couple weeks after i bought my truck 3 years ago i had it still under warrenty at the time ford said they just did a basic service on the tranny, its been great ever since
Old 08-12-2011, 12:15 PM
information regurgitator
If you have 150 bucks kicking around, and wouldn't mind dropping the tranny pan and doing a little work, THIS might be just the ticket!
