loud whining noise - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-15-2007, 06:37 PM Thread Starter
Question loud whining noise
Please help! I own an '06 F250 PSD FX4. This is my first Powerstroke and I love it. I have been hearing a loud whining noise at times upon takeoff or acceleration. The noise is similar to the noises described by those towing up a long hill, but it does this at times just driving around town.The noise does not occur all the time and sounds like a loud fan kicking on. It may only last a second or it may last several seconds. I did not notice it until the summer months when the weather got hot, so I thought it may be some sort of cooling fan. Is this some sort of fan? If so, is it normal to kick on and off like that around town? Thanks for the help.
raider1 is offline
post #2 of 10 Old 08-15-2007, 06:42 PM
djordan1184's Avatar
yes it is a cooling fan.And if it's hot enough outside and your truck temp get up there it will come on "also check your coolant to make sure it's full
2006 f-250 supercab
8" superlift new rear leafs no blocks
dual stabalizer superlift
20" american racing rims
wraped with 38"x15.5" mickey thomson MTZ
manic light bar on front with kc lights
Bushwacker pocket flares
Banks six gun tuner with PDA and 4" turbo back exaust
soon to have spare bed tire mount same rim and tire
light bar for bed and more kc lights
super lift track bars
nurf bar running steps
and banks innercooler
djordan1184 is offline
post #3 of 10 Old 08-15-2007, 06:47 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
that would be your fan clutch engaging, causing your fan to spin faster to draw in more cooling air. no worries my friend, it is totally normal.
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #4 of 10 Old 08-15-2007, 07:38 PM Thread Starter
Thanks for the help! One more question, when the noise started today, I stepped on the accelerator a bit and the rpm's wound up but the truck did not "take off" like it does when the whining noise is not happening. Is this a normal lag when the fan kicks on? Thanks again.
raider1 is offline
post #5 of 10 Old 08-15-2007, 11:56 PM
yep thats normal too,it takes some power to turn the fan.just be glad its not like the newer mack's at my work,when the fan kicks in on them you lose like 70 horsepower
2005 F-250 XL reg. cab 4X4,6.0,torqueshift,
autometer phantom series gauges,mbrp 4" turbo back straight pipe,sct xcal2 w/ innovative diesel tunes(running extreme street) SOLD
2008 Chevy HHR SS
TomM is offline
post #6 of 10 Old 08-16-2007, 03:40 AM Thread Starter
Thanks. It just seemed like it did not want to go for a second. Will an exhaust and/or intake help this "lag" in power?
raider1 is offline
post #7 of 10 Old 08-16-2007, 03:57 AM
There are LOTS of things that will help you make more power on that 6.0
When the fan comes on, it is moving LOTS of air... just make sure your coolant is good and you should be good to go.
Also, the turbo will make a whine or jet engine sound... when you floor it from a stop, that will take a second or so to spool up... so if its a loud whistle you're hearing - this is what it is and YES, and intake AND exhaust will help it spool faster and reduce your "lag"
Blue01F250 is offline
post #8 of 10 Old 08-16-2007, 03:58 AM
Oh yah, and WELCOME to the .ORG!!!
post #9 of 10 Old 08-16-2007, 02:08 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
the stock exhaust is pretty restrictive compared to a 4'' or 5'' kit. putting one of these in will help in the lag department, as for making more power i dont know. i didnt really feel that much in the power area but it sounds a lot better! if you are wanting more power, i suggest a tuner, but you need to have a good set of gauges first so you can see what temps you are running at.
at any time.
Rob is offline
post #10 of 10 Old 04-14-2009, 06:04 AM
T.R.P.'s Avatar
I am having this with my 06. It also does it when I am parked and rev the motor up. The more RPM's, the louder it gets. It sounds like a vaccum is getting closer and closer to my ear. There also is a burning smell when I let off after it does this.
T.R.P. is offline
