K what now PLEASE HELP
K guys what now. I have a 03 ford f350 6 liter and i had a high pressure oil leak and when it was warm it wouldnt start. So i replace my head gaskets,apr studs,hpop, stand tubes, icp sensor, ipr valve and here is what my issue is now. Today i fired it up and truck ran perfect. shut it off when it got up to temp and it fired right up, the hot start issue was gone. YAY. I went for a spin around the block and the truck was running awsome and when i went to step on it i heard a pop and when i step on it again now there is a wack off black smoke and no power.you can hear the turbo spool a bit but on my sct live wire gauges it will not built any higher than 2 pounds of boost. What could be cause this now. is there something i can check
Possibilities are you popped a boot off the CAC tube or split one. You could have popped a plastic end tank on the intercooler, or you blew out the bellows section of an up pipe or y pipe. It is one of those things. Most likely a boot or up pipe.
