No power below 1800 rpm's
Hi everyone I am new to the forum as well as ford diesels. I just traded my van for a 2004 f250 2wd x-cab it ran great but on day 2 i was sitting in traffic and it started skipping. Now it has no power taking off until i get over 1800 rpm then it runs great. Once it is in overdrive and rpm drops it sputters and shakes until it down shifts. Here is a list of everything I know about the truck
127k miles 2 new batteries installed on 8/6/11 new injectors per PO new ficm looks new and i tested it yesterday 47.7 at key on, crank and run removed egr and cleaned now has been unplugged for 50 miles and no codes it has no CEL or codes runs the same with ICP unplugged runs the same with egr unplugged all fuses good temp on scanner is 194* starts right up (about 2 seconds) no smoke at idle, driving or when i open it up any ideas of something i may have overlooked Thanks |
check your trans line pressure i noticed in mine after installing a programer it ran wild and then stoped and theres no code that pops up for that not that im aware of or found now the skipping thing i would change the oil your injectors run off oil psi you could be low spend some money and get rev x additive or hot shots secret that helps alot and use the motor craft filters on all your filters and last change your fuel filter one thing ive learned about these trucks is fluids and filters is key
Just a guess but do you think it could be the variable geometry turbo actuator going bad. If it does not open and close in a timely manner due to sticking or just a bad actuator it will be very, very sluggish as low speed and rpm. Kind of like trying to start pedeling a 10 speed bike in gear 7.
The link has the turbo diagnostic document in pdf, may shed some light. DTS Articles - Coffee Table Books |
