Okay guys what would you say - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-04-2011, 06:31 PM Thread Starter
I have a 03 ford f350 6 liter with a no start when hot issue. I got feed up with the one and only shop we have here and torn this thing apart myself. I bought a new hpop and new ipr valve and icp sensor and 2 new stand pipes. what my question is now is there an o ring that goes on the bottom of the hpop and if so can some one please post a pic of it.i know one goes on top where the turbo conects on and another one where the bracket bolts onto the pump just not to sure about the bottom. I also have another question for you the pipe that connects to the hpop is that where the sct fitting is or can someone please post the pic of that also.
When they mean check the backlash on the hpop gear how do you do that if you dont have the tool. I was told as long as it all goes together fine it will be fine because there is no way to adjust the backlash on this system. can someone please run me through this im waiting on replys before it goes back together
bedrockbobcat is offline
post #2 of 3 Old 08-04-2011, 06:44 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Being an 03, you don't have an STC fitting on your HPOP. Those were used on 05-early 07 engines.
As for the O-ring, I haven't worked on an 03, so I really can't answer. The 03 and 04's are a different set-up that the 05-up engines.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 3 Old 08-04-2011, 07:03 PM Thread Starter
not to sure eaither just need to get this back together and been looking through this sight for the past 2 hrs now
