is 45volts ficm output ok ? - Ford Powerstroke Diesel Forum
Old 07-29-2011, 01:36 PM
the dealership diesel tech thinks its ok. Everything I read it should be around 48volts ?
Old 07-31-2011, 05:47 PM
I just started watching mine, and it stays at 48 for startup, and will vary while driving. I have see in drop to 45v but only for a second.
Old 07-31-2011, 07:16 PM
Lowest I have seen mine is 47.5 volts. According to some, I am in for doom and gloom. I would like to know what happens if it falls lower. What does it destroy?
Old 07-31-2011, 07:22 PM
Feedback Score: 9 reviews
45V-48V at all times is the Ford spec. Any lower and you'll need a new FICM.
Old 08-01-2011, 02:12 PM
Powerstroke Techie
Feedback Score: 3 reviews
at 45v keep your eye on it. my new ford ficm reads 48.50-49.00v all the time
Old 08-01-2011, 03:33 PM
thanks for the info, I just had a alternator go bad and the engine cut off. It's been in the shop now for 12 days . The tech is stumped, because the engine still has a random shut-off. He does'nt think the ficm is the problem,but other posts on here say after the alt. goes out, it can take out the ficm also. Not had any issues prior to the alt.
Old 08-01-2011, 04:48 PM
Powerstroke Techie
may be a wire chafe issue
Old 08-03-2011, 01:41 PM
How do ya'll monitor the ficm output volts ? Does the edge insight show this ? If so, any recommendations on the best place to purchase one online ? thanks
Old 08-03-2011, 01:42 PM
I just bought a Insight CTS and it shows FICM voltage. The FICM voltage should hold steady no lower that 47V all the time, any lower and the power supply either needs to be replaced or repaired.
Old 08-03-2011, 01:47 PM
Slacker
Feedback Score: 4 reviews
Here's a link to how to check it using a digital voltmeter.
LINK
