dtc code p281,after egr removal..
I just replaced my oil cooler and did and egr delete,now I am getting this dtc - P281 - Cylinder 7 Contribution/Balance. Is this an expected code for egr delete ? I didnt have it before,but sort of figured I would get some dtc once removing the egr cooler. Any ideas..... thanks,Robert
The expected code for an egr cooler delete is the infamous P0401 code (insufficient EGR flow detected).
Contribution codes usually mean bad injectors. Since you had the injector harness off the truck, unplug #7 at the head check the pins and plug it back in, then get the clip on. I had a bunch of odd codes from not getting the FICM plugs all the way in when I finished... ![]() PS: Cylinder #7 is the one closest to the firewall on the passenger side. |
![]() Thanks for your help too,I used those write ups in ur signature . |
If you have anything you want to add to that post, let me know. |
