Ideas anyone? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-25-2011, 07:34 PM Thread Starter
Ideas anyone?
Need your thoughts please
When coming to a complete stop in my truck I feel a "thunk" like something is slipping and than again when I accelerate. Is this a transmission issue, rear end issue or something else? Trans has no other slipping or any problems so I not sure if I can pinpoint the trans. Need some help please. Thanks '03 f250 6.0L.
Russ is offline
post #2 of 5 Old 07-26-2011, 05:20 PM
Is this a new symptom? Ford has put out several TSBs that says a lot of these bumps, thumps and clangs are “ normal” . A lot of this has to do with lash and excess clearances in the drive train components. My 05 does the same thing.
HAM_RADIO_MAN is offline
post #3 of 5 Old 07-26-2011, 06:16 PM Thread Starter
Thanks for the response. It has been doing it for a while, just not sure when it started. I'm hoping it's not too serious. Was not sure if it was rear brakes or trans.
Russ is offline
post #4 of 5 Old 07-26-2011, 06:38 PM
silversuper's Avatar
just bought my truck which appears to be the same truck as yours, and I have the same noise. a mechanic drove it today and asked about it. Let me know if you figure it out
Rich
2003 f250 4wd 6.0 diesel crew cab long bed Lariat.
119k on the clock, stock
has: tires, edge insight monitor, new ICP sensor and connector, new front pads and rotors, PMM EGR delete kit, new oil cooler, BOSS 9' plow
needs: tuner, coolant filter kit, blank check
silversuper is offline
post #5 of 5 Old 07-27-2011, 03:35 PM Thread Starter
Silvesuper- I will definetly post if problem is found and same with you. It drives me up the wall!
Russ is offline
