ABS - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-21-2011, 05:55 PM Thread Starter
ABS
MY ABS light is on. I have scangauge 2 and it is not showing any codes. Did check the fuse. Does anyone have any suggestions
race735 is offline
post #2 of 2 Old 07-22-2011, 06:31 PM
A ScanGauge won't pull those codes.
More times than not it's the Vehicle Speed Sensor (VSS) on top of the rear differential. Pull it out and see if it's got a lot of metal shavings/fuzz on it (from a Limited Slip rear end , if you have it). If it does, clean it up, reinstall, and see if it clears. May have to drive it a little bit to get the code to clear.
If that doesn't fix it, you can try replacing the sensor. Part no's Ford#6L3Z9E731A or Motorcraft DY1073. Should be about $50.
Check the wiring to/from the sensor. The ABS is very picky about the correct voltage. Any insulation missing or if, by chance, a wire is broke, get a new pigtail for the sensor.
dieselmac is offline
