HPOP oil pressure vs. LPOP oil pressure... - Ford Powerstroke Diesel Forum
Old 07-20-2011, 05:55 PM
Hello people!
'05 F250 6.0 PSD:
1) Is the oil pressure gauge on dash monitoring lubrication circuit's oil pressure (LPOP), or is it monitoring fuel system's oil pressure (HPOP)?
2) Is "LOW OIL PRESSURE" warning all about lubrication circuit, or is it about high pressure circuit, or maybe either?
3) Is it possible for IPR to fail due to a very simple problem like easy removing dirt or not so important foreign object?
Does it woth it (in applicable cases) to try to fix a stucked IPR only by cleaning the part or removing some not catastrophic obstruction, or every time it gets stuck means replacing the part? (It is not cheap).
How bad or agressive does an obstruction needs to be in order to damage IPR's integrity?
Can the solenoid coil be damaged (overheat, open circuit) when an obstruction doesn't let the valve section move?
All hypothetical scenarios, just sharping my 365VGT knowledge, Thanks for sharing yours!
Old 07-20-2011, 06:02 PM
The Tamed Racing Driver
The dash gauge is for the low pressure, lube circuit only, same with the light.
Old 07-20-2011, 07:17 PM
Originally Posted by kaliman78alfa View Post
Hello people!
'05 F250 6.0 PSD:
The dash gauge is controled by an open set of contacts on a pressure switch and is worthless for tell you anything other than there is a minimal amount of lube oil flowing ( low pressure oil)
Low pressure lube oil only. A HP oil fault will result in a DTC for low ICP( injection control Pressure)
YES
Is it worth it (in applicable cases) to try to fix a stuck IPR only by cleaning the part or removing some not catastrophic obstruction, or every time it gets stuck means replacing the part? (It is not cheap).
In the industrial world we clean out hydraulic valves all the time. A rebuilt IPR is cleaned maybe new seals and a fresh screen. Sometimes only a screen is replaced. I would NEVER use a rebuilt IPR in someone else’s truck. However I might re-screen one and use it in my truck if I had reason to belive nothing got past the screen. AT 4000 psi anything that hits the screen is going to have a lot of impact force. This is all a judgment call on how much you want to take a chance on the reliability of the valve. I would say if your IPR was a time bomb waiting to go off that would be a bad thing. Theoretically you could flush an IPR and re-screen it. If none of the ports were clogged and the seals are OK it would be fine. The problem is 99% of the world doesn’t have the capability to verify the integrity of the valve before installing it. Troubleshooting time and Labor costs make replacing the IRP with a new product the most cost effective solution.
Anything that gets past the screen can damage the sealing surfaces , clog the ports and destroy the valves functional capability
The solenoid is duty cycle modulated in operation so by applying 12 volts to it you are effectively running it at 100% duty cycle. I would not put 12 volts to it for more than 30 sec at a time ,but some say 60 sec is still OK For testing and trouble shooting . I don’t think an obstruction by its self will harm the valve electrically
All hypothetical ( NO This is real world stuff ) scenarios, just sharping my 365VGT knowledge, Thanks for sharing yours!
Glad I could help.
