Please Help Misses & Bucks is it FICM? Injectors? Bad fuel?
So just wanted to hear some suggestions of what it could be and I have done some searching around on here. Here is what is going on and this just started on Friday right before my drive to LA.
Start truck in the morning or when cold and it idles just fine no miss, no smoke. When it idles up close to 2k rpm (only when it is around 2k rpm) it falls on its face and misses then a puff of smoke. It smells like unburnt fuel. Even when I let truck idle for maybe 5 to 10 min more (or when temp is warm) it still does the same thing. However; when its been running for a little longer everything is fine and runs like a top. The whole drive to LA was fine with no problems what so ever, even climbing the Grapevine it climbed it like champ Next morning I start it up to go get some fuel it does the same thing, so I think maybe injectors are dirty so I get some additive and put it in the new fuel. Next morning start it up same thing as before with the missing. Drive it back to Northern California and no problems on the drive and was doing 85 most of the way. Start it this morning (after a new tank of fuel after the drive) and no misses or smoke ran great. Now I wont know if the problem is gone until tonight or tomorrow but if not what could it be? A failing FICM? bad Injector? or was it just bad fuel? |
Sorry man, we need some hard data for a problem like that. What kinds of mods, tunes, repair history, milage, DTCs etc… I have a 6.0 crystal ball and a WIFI 6.0 diagnostic magic 8 ball I could use ,but that would be of no use to you. Does your truck have an EGR valve and when is the last time you cleaned it. Ever cleaned the turbo? Have you check your FICM voltage? I’m not trying to be rude, but to help you we need more info. Might just be time for some REV-X
Mine does the same thing, I have a CTS and it stops surging around 175 degrees oil temp. Others that have had this problem point to either the egr valve and others had problems with stiction on the injectors and that rev x took the problem away after about 1000 miles after rev x, I know that's what I'm trying next rev x is cheaper than new injectors
Honestly I don't know mine only surges if I go above 50mph so until warm I won't go faster than that
Check FICM voltage when cold, cranking and running. If its less than 48 volts FICM bad. If FICM check out then order some rev-X.
CHECK OUT THE LINK BELOW 6.0 Repair Help - Ford Powerstroke Diesel Forum |
Put the scan tool to the truck and it gave all 8 cylinders low injector voltage but FICM pulls 48v ingnition on, 48v cranking, 27v running. Any ideas
If you typed that right, and your FICM voltage is 27 volts while running, I'd say you just found a key contributor to your problem
Its to bad my warranty was up last year but I have read that somethings on the truck are still covered under the "Emissions Warranty" and being here in California they are very strict about emissions. Does anybody know if the FICM is covered under this or how I could find out what is covered?
Check swamps for 58v ficm yours is bad and I would not run it at 27v for fear of fuel injector failure.
