6.0 to a 7.3??? - Ford Powerstroke Diesel Forum
Old 07-13-2011, 08:04 AM
6.0 to a 7.3???
I got a question. My 6.0 needs injectors and our repair shop says 2800 to fix it and it might happen again soon. So my question is will a 7.3 drop into my truck with out a big pain in the as*? and will my trans bolt up? or do i need another tranny? Thanks Ron
Old 07-13-2011, 08:32 AM
My guess is you could do the injectors 3 or 4 times for what a 7.3 swap would cost. You would need a complete donor motor, 4r100 trans, complete wiring harness with computer, the IDM, etc.... Then you run into the problem of things like gauges working and such.
Fix the injectors, sell the truck and buy a 7.3 would be a MUCH cheaper route to go imo if you are really intent on getting rid of the 6.0.
But honestly if you hit up a place like warren diesel or casserly (full force) you will get injectors that will last a LONG time if you properly maintain your truck. Just sayin...
Todd
Old 07-13-2011, 08:35 AM
clean fuel, proper fuel pressure, good and fresh 5w-40 synthetic oil, and proper FICM monitoring should keep your injectors running forever really.
