Coolant flush?
I am in the process of doing an egr delete for precaution measure only. Also installing coolant filtration while im at it. Removing gold coolant and replacing with elc. i have experienced no problems to say. i have noticed that everyone is saying that you should not had more that 15 degrees between eot and ect. If i delete the egr cooler, do i still need to monitor those, if so is the degree of difference the same without egr cooler. Also when doing a coolant flush, do you necessary need to replace oil cooler, no problems to note, just thinking i am going to be that far in. Does a cooloant flush possibly help clean the oil cooler or possibly make it worse or maybe finish it off. Can oil cooler be cleaned when taken off the truck?
Good questions. About the oil cooler, and monitoring EOT and ECT temps...if you still have a oil cooler that can plug up (which you will, and it still can later from possible debris) you need to continue to monitor both.
You don't technically have to replace the oil cooler along with the flush but from doing the flush you run the risk of clogging your cooler up with all of the contaminates broken free from the flush.
You will still have to monitor the ECT and EOT temps as the oil cooler will still be operating as normal even with an EGR delete installed. The ECT / EOT temp delta tests to see if the ECT side of the oil cooler is clogged and has nothing to do with the EGR delete. The EGR delete's design is to prevent the EGR cooler from rupturing which will cause coolant to enter your intake which will increase the pressure in your heads leading ultimately to head seperation and necessitating a head gasket replacement. Red up the coolant flush info in my sig and also read up on doing an oil cooler reverse flush (which can be done with the oil cooler still installed on the truck) this will help to prevent the oil cooler from getting clogged up during your flush. Also don't forget the block plugs during the flush! If you don't want to remove the starter to get to the passenger side at least pull the driver's side and make sure you flush through it as well as the through the radiator. |
For those who are just learning about the 6.0 issues...and With all due respect, the Oil cooler being clogged up tends to be the primary cause of the EGR cooler destruction by overheating. Monitoring the Oil temp is the method to which determine if your EGR cooler is at risk. |
This is the stock design: ![]() (lost the other half of the image watermark when I copied the URL over, image is from BPD) Now at any time any of those passages themselves can become clogged from the Ford Gold silicates or they can fail and rupture just as the oil cooler can. The can and sometimes do fail hand in hand but one is not directly related to the other. |
Thats a funny thing...I have never heard of the oil coolers rupturing, but only plugging up, of course then to cause much higher oil temps, and also, to then starve the EGT cooler of important coolant flow, causing the EGT cooler to burst/crack.
Maybe someone will chime in and change my mind about Oil cooler ruptures
Most of the time when there is oil in the coolant it is because the oil cooler ruptured on the oil side. It isn't as common as the cooler plugging up but it happens and when it does you need to remove all the oil from the cooling system.
Thanks to all for the valuable info. i will attempt to check flow of the old cooler and possible flush it. If not, guess its a new oil cooler, thanks again
