power stroke diesel problems - Ford Powerstroke Diesel Forum
post #1 of 59 Old 08-09-2007, 05:48 PM Thread Starter
i have an 03 ford f 250 6.0 power stroke diesel and it will not accelerate over 1000 rpm and if you try to drive it it has no power it whistle really loud so i thaught the turbo be good and it smokes bad wht blue and i replace all the filters and replace the TP sensor and it is getting fuel dont know how much it starts fine runs fine and no check engine light and no codes could it be the turbo you can hold the accelerator to the floor and it will not go over 1000 rpm i have checked the tubes and every thing does any one have an idea what it could be
tj1974 is offline
post #2 of 59 Old 08-09-2007, 07:05 PM
Tacomarunner's Avatar
Punctuation maybe?
Russell
O7 F-5504dr 4wd cab and chasis w/ 12' Scelzi service body 6spd manual trans. 200" WB 17,950 GWWR 4.88 gears
Overhead gauges w/ EGT and Boost. FCDP EGR Delete. AEM Workhorse CAI. Down pipe only, no cat or muff.
Tacomarunner is offline
post #3 of 59 Old 08-10-2007, 12:03 AM Thread Starter
what do you mean.
tj1974 is offline
post #4 of 59 Old 08-10-2007, 04:02 AM
Manatee's Avatar
Originally Posted by tj1974 View Post
what do you mean.
Since you asked: your post is one, long, run-on sentence with a bunch of misspelled words and grammar that does not work. None of us here are English professors buts your post "runs" a bit more than most
No big deal, Tacomarunner was just giving your post a bump to the top, just like I am.
Hope someone chimes in to help. I don't know too much about wrenching, but the blue smoke can't be good. Good luck
The Manatee
15 F350 Long Bed, Crew Cab, Lariat 4x4, 6.7 PSD
Manatee is offline
post #5 of 59 Old 08-10-2007, 05:25 PM Thread Starter
ok i did not think this was grammer school but ok the blue smoke is from the oil thats out of the turbo thank you for your concern with my spelling and run on EXCUSE ME
tj1974 is offline
post #6 of 59 Old 08-10-2007, 05:34 PM
WEWILLE's Avatar
Hey its ok they were just bumping your post back to the top. Does it run fine, with now smoke all the way up to 1000 and then it just stops reving, or just bad all the time? Just a wild guess egr cooler maybe? Is the truck still under warranty?
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #7 of 59 Old 08-10-2007, 06:29 PM Thread Starter
no it is not under warranty an d i took the exhaust pipe off back of the turbo and it is full of oil and it does run fine and starts fine and no check engine light and no codes the oil i think should not be in the exhaust out of the turbo right it you can accelerate it but it will not go over 1000 rpm like no boost pressure
tj1974 is offline
post #8 of 59 Old 08-10-2007, 07:01 PM
Maybe try removing and inspecting the egr valve to see if it is caked with carbon deposits or maybe stuck.
grabowskimech is offline
post #9 of 59 Old 08-10-2007, 07:16 PM Thread Starter
ok i thaught bout the egr but i cant seemed to get it pryed out where it is mounted i can turn it but it will not pry ou but what bout the oil in the exhaust tube that connects to the turbo i thaught that should be dry the egr is they a special way of getting it out?
tj1974 is offline
post #10 of 59 Old 08-10-2007, 07:21 PM
your turbo is done
2005F250 is offline
