6.0 lack of power while towing??? - Ford Powerstroke Diesel Forum
Old 08-09-2007, 09:31 AM
Hi guys this is my first post. I have a 6.0 2006 f250 with a banks six gun anf 4" turbo back exhaust. running 35" tires with 373 gears. I pull a 31' traveltrailer that comes in at 8,000 lbs. my truck seams to have a real problem towing this up any kind of grade. I have to get a run at hills to only have it loose MPH. It will then down **** hit around 2500 RPM's and hold there or decelerate.I can never gain and speed,while my buddy in his dodge pulling a 37' 5th wheel blows right by me. I have to wait till of the hill and then I can start gaining speed again. Seams to rev just fine but not much power. Any idea's. I'm thinking bad turbo. ????????????????
Old 08-09-2007, 09:38 AM
duct tape & zip ties
I am thinking possible clogged egr valve, or you need to clean the turbo. I am no expert on the 6.0L's. But if you are having low power issues from what I have read it usually seems to be the egr valve and the turbo needing cleaning. Being I never done this I have an Idea of what needs to be done to do the job. But it will be better for some one else that has more experince with the 6.0L then I to explain it. I am sure one of our great techs will be along soon to help you out.
Welcome to the Org. There is alot of great people on the site and alot of good info.
Old 08-09-2007, 09:40 AM
any codes? My first thought is dirty fuel filters, or a sticking turbo.....
How many miles on the truck and when was the last time the fuel filters were changed??
Old 08-09-2007, 09:41 AM
thanks Big country, it's going into the dealer on monday, I'm just having a hard time with this.This is my first ford.
Old 08-09-2007, 09:42 AM
Truck has 22,000 on it it has had 1 fuel filter change so far. no codes
Old 08-09-2007, 09:44 AM
what level are you towing on with the six gun??
Old 08-09-2007, 09:46 AM
between 3 and 4
Old 08-09-2007, 09:47 AM
try backing it down to 2 and see if that helps...
Old 08-09-2007, 09:56 AM
i've tryed every setting even stock . it revs fine, never misses, just doesn't seems to have any pulling power. when I run it without the trailer on setting 4 it goes like a raped ape. it just happens when you put any type of load on it. I even noticed that when I pulled a empty 6x12 uhaul trailer it seemed sluggish.
Old 08-09-2007, 10:00 AM
see what the dealer says....sounds like a potentially binding turbo to me...
