6.0 cooling system flush - Ford Powerstroke Diesel Forum
post #1 of 22 Old 06-12-2011, 05:05 AM Thread Starter
Brian82's Avatar
Got 95,000 miles on my 06', im ready to flush the cooling system. Been reading a few things on here about the methods other people are using beside the old garden hose. If anyone could give me the .. start to finish suggestions including cleaners used, and how much distilled water.. ect. and any other coolants i can use besides Fords Gold stuff.
Thanks brian
Brian82 is offline
post #2 of 22 Old 06-12-2011, 05:30 AM
There are threads here on how to do it..........HOWEVER, which ever way you choose, be prepared to replace your oil and EGR coolers. For the 6.0, it is a way of life.............
Aussiekeeper is offline
post #3 of 22 Old 06-12-2011, 05:35 AM Thread Starter
Brian82's Avatar
I do plan on replacing the EGR with a delete kit, was going to wait for the oil cooler to fail before replacing it. maybe.... we'll see.
Brian82 is offline
post #4 of 22 Old 06-12-2011, 05:39 AM
Generally, the flush will stir up the casting sand in the block and plug the cooler, so, I would advise doing the flush when you have the means to replace the coolers. I just had mine done after a flush, as others have. Dealer told me this is a common problem after a flush.
post #5 of 22 Old 06-12-2011, 05:56 AM
taskforcefreddy's Avatar
Paging Mitch... Paging Dr Mitch on line 2. Oh hell, I'll do it. This is just in case you didn't find these already. If you still have questions, let us know.
Here's my write-up with a few notes...
Just changed coolant to ELC... a few notes for everyone
Here's Mitch's (PGreenSVT)
Flushing and Cleaning the 6.0
taskforcefreddy is offline
post #6 of 22 Old 06-12-2011, 05:58 AM
Galaxie's Avatar
Do it right and make sure your are not pluged now. If its not, you should be fine. If it plugs, you are going to have a problem if you flush or not.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #7 of 22 Old 06-12-2011, 07:10 AM Thread Starter
Brian82's Avatar
Thanks for the replies, how would you tell if your currently clogged up besides actually leaking coolant EGR, and/or oil leaking into coolant.
Also when i turn my truck off, i Puke, or cough coolant back into the coolant degas container. nothing comes out of the tank, but you can hear it when you turn the truck off, is this normal.. and/or a sign of my EGR cooler being clogged with soot and having hot spots in it?
i will read the other coolant flush posts, thanks for the links
i am new to this truck, bought it second hand about 3 months ago. Had changed oil and fuel filters. Getting ready to change trans external filter and pan fluid. also doing coolant flush, checked the rears, transfer case fluids are good too. Already put a Fuel injector in the truck. wasn't too happy about that after buying the truck 3 months ago.
So which ELC should i use.. are they all the same. just to to the store and buy any ELC? guess it wouldn't matter after flushing the system. and this is not mixed 50/50 anymore. ?
Brian82 is offline
post #8 of 22 Old 06-12-2011, 07:25 AM
Hi. Sorry guys. This is a wife trying to get her husband information on how to do this as well and I'm probably about to ask a stupid question. I see from a chain auto parts store that is in this area that there is a Restore Fuel Injection Cleaner product and a Restore Oil Treatment product? Are either one of these the Restore you are talking about to use to flush out the coolant? Keep in mind, I know nothing about motors.
graysellshouses is offline
post #9 of 22 Old 06-12-2011, 07:53 AM
Brian... The best way to determine the condition of your oil cooler is to get a monitor such as the Scangauge II. I recently saw them on ebay for $125. There's flashier ones out there but as far as bang for your buck is concerned, the Scangauge II takes the cake. Withthis, you can monitor your ECT and EOT's. At 55mph on flat, even highway there should be <15 degrees difference between your ECT/EOT with the EOT always being a little higher. That is step #1. If it's greater than 15 degrees, you need a new oil cooler before anything else and you need it quick.
Gray... No. Restore is usually purchased either online (sometimes difficult to find) or at a tractor service shop. I found mine at a peterbuilt garage in el paso.
post #10 of 22 Old 06-12-2011, 08:05 AM
Sorry brian... should've elaborated. if you're oil cooler is clogged, it will restrict coolant to or from your EGR. Once this happens, the EGR will burnout but it also decreases the flow which also superheats the coolant that's inside of it causing it boil over. It can also cause the heads to warp which will cause greater issues. When this happens, your headgaskets can go and this in turn will cause increased pressure in the coolant system leading to your coolant to puke out the degass bottle. Generally speaking, all this is generated from a bad oil cooler which is why it's important to be able to monitor the temps between your coolant (ECT) and your oil (EOT).
The Following User Says Thank You to taskforcefreddy For This Useful Post:
gtspowerstroke (04-19-2016)
