Why is my 6.0 running hot? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-30-2011, 06:52 PM Thread Starter
Guys -
Need to pick some brains here. Myself and one of the other members of this site (he's been doing some work on the truck) are trying to figure out the temps I have been seeing on my Insight CTS. The delta is great - only 3 degrees the majority of the time. However, the ECT and EOT hit 217 and 220 the other day pulling a 26' bumper pull trailer. I pulled my 18.5 foot sea ray today and hit 210 and 212, ECT and EOT on flat roads, not pushing it hard at all.
I run between 193 and 195 EOT and 196 and 198 ECT without towing.
Here's what has been done:
Full Coolant Flush with Restore, Restore +, New ELC EC-1 Coolant
Remote Dieselsite Filter Setup
New Oil Cooler (we believe old cooler was blocked from remnants loosened up with the flush )
RCD EGR Delete
Any thoughts, ideas why I am getting these temps? Do you guys run this hot?
There is no tune on the truck at all.
Jon
indyjon is offline
post #2 of 12 Old 05-30-2011, 07:12 PM
dz4swamper's Avatar
Maybe a t-stat stuck half closed? I'm running 188-190 empty at 60.
2004 CC/LB F-350XLT 6.0L
Banks techni cooler
Banks High Ram intake and boost tubes
4" Exhuast
Banks IQ
SCT
Tuned by Vivian (Street, Looney, Looney Wild, Tow and Tow Aggresive)
ARP studs
Black Onyx HG
Cat ELC
CCV mod
No Kitty
Diesel Site Coolant Filter
dz4swamper is offline
post #3 of 12 Old 05-30-2011, 07:26 PM
Originally Posted by indyjon View Post
Guys -
RCD EGR Delete
Jon
Jon
your temps are fine, the t/stat starts to open at 192.2 and is fully open at 219.2 and your fan should come on around 212-214*. I have see temps of ECT 218* and EOT 228* pulling my 14k 5er up a 6% grade over 6 miles at 90*+ outside so you are OK.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #4 of 12 Old 05-30-2011, 07:55 PM Thread Starter
I have my suspicions with the t-stat as well.
2stroker - I want to think these temps are OK, but I hear a bunch of guys running considerably lower temps.
That camper I pull isn't very heavy @ < than 5,000 lbs. 14K I understand, but 5K should not get this motor that hot.
indyjon is offline
post #5 of 12 Old 05-30-2011, 08:00 PM
roary's Avatar
What are your outside temps? Where are you located at?
2003 XLT CCSB
6.0 Auto 3.73
5500k HID 55w DDM Kit
Gryphon with Custom Tunes
65hp Light Tow
80hp DD
120hp Race
140hp Extreme
Check out PHP
if you are interested!
roary is offline
post #6 of 12 Old 05-30-2011, 08:02 PM
Goose350's Avatar
Whats the ambient temp?
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #7 of 12 Old 05-30-2011, 08:11 PM
OK you have to go out and get on the freeway set the cruise at 60mph on flat ground after about 2 min take your readings this will give you a true reading of your ECT EOT this is what you go by, pulling is not a true way to read temps it is just a guideline for higher temps.
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
post #8 of 12 Old 05-31-2011, 06:10 AM Thread Starter
I am in Indianapolis. It was 85 degrees last weekend with the camper and 90 degrees yesterday with the boat.
indyjon is offline
post #9 of 12 Old 05-31-2011, 06:15 AM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Jon, I would suspect that your camper weighs more than that and would explain your towing temps. My suspicion is that is your dry weight before loading up your water, propane, clothes, accessories, etc. Loaded you are probably seeing about 6k lbs or more. My old 26ft lightweight travel trailer was about that same weight.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #10 of 12 Old 05-31-2011, 06:26 AM Thread Starter
Shawn -
I certainly agree if it was loaded. The camper was empty - nothing loaded. Water drained, no clothes, food, etc...
It's dry weight is 4400 lbs.
indyjon is offline
