Bad ground mess with FICM????? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-02-2011, 09:26 PM Thread Starter
Adam03F250's Avatar
Question Bad ground mess with FICM?????
Is it possible for a bad ground to mess with the FICM? If so dose anyone know where the ground points to check would be located on an 03' 6.0 FX4 supercab... Long story short my insight has been reading 24-26v for FICM since i installed it a few weeks ago, then today turn it on 47-48V engine cranked over perfectly ran it a min then turned it off back to 24-26V and thats the reading i've gotten ever since this afternoon.
03' F250 XLT Supercab Shortbox
FX4 6.0L Auto
Edge Insight CTS
Swamps 58V FICM
Cheveron ELC Coolant (Meets CAT EC-1)
285/75/R16 Maxxis Bighorn Tires
Adam03F250 is offline
post #2 of 3 Old 05-02-2011, 09:53 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Yes, a bad ground on the FICM will create havoc.
I believe that the ground for the FICM is on the turbo heat shield bracket, where it bolts to the motor, down low theres a stud that has a ground wire on it.
You can add a ground wire to it as well. Using the bracket and grounding that to the engine.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 3 Old 05-02-2011, 10:45 PM Thread Starter
Adam03F250's Avatar
Awesome, I will have to check that out in the morning. I did just order a swamped 58V for the truck as well but i want to make sure i have no ground issues before i install it!
FX4 6.0L Auto
Edge Insight CTS
Swamps 58V FICM
