ECT Sensor & Fan Question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-13-2011, 05:34 AM Thread Starter
If my Coolant Temp sensor is going bad will it make my Fan Kick in and out ?
Noticed yesterday at about 90* ambient temp and running 80mph on highway fan is surging off and on but temp gauge was showing normal range...this a.m. coming to work temps showed way cooler than they normally run ..stopped at store to grab a drink ..came out temps back up in normal ( about 1/2 way in middle on gauge ) as soon as I started out onto feeder ramp looked down and it was barely above cool ????
Radiator and degas are at proper coolant level
could it be giving false readings to the fan clutch ?? what controls it ??
'05 F250SD > Ranch Hand HD Bumper w/skid plate & KC's, 2.5" Leveling Kit, Firestone Rear Bags, 305/17 Goodyear Wranglers, Hide-a-Ball Hitch, SCTx3 by Vivian , EGR Delete, 4" open exhaust , 6.4 Banjo Bolts , Fuel Reg. upgrade kit , cold air intake by me , '03 Turbo by HPTurbochargers,46 gal.aux.tank, ARP Studs / Factory Gaskets.
Rmorgan711 is offline
post #2 of 8 Old 04-13-2011, 12:08 PM
The fan will come on when the coolant temp hits around 212* and if you are counting on the gauges to tell you when things are hot you are wrong, when they hit hot it is to late you are in a melt down. You need to get gauges like the Edge Insight to tell the difference in EOT-ECT max 15* i think 10* your cooler are starting to get plugged a coolant flush may help if it is not to bad but gauges are the only way to tell. Here is a coolant flush that may help.
This is a post by PGreenSVT
Flushing and cleaning the 6.0
Restore is for cleaning out any silicate goo. VC-9 is for cleaning out iron and scale. Restore Plus is the same as VC-9 and cheaper.
To flush drain the coolant by removing the lower radiator hose from the radiator, and removing the drain plug from the driver side of the block. There is a drain plug on the passenger side also but you have to remove the starter to get to it. I don't bother with that one. You can skip the block drains if you want except for the final drain before adding fresh coolant. You will just have to flush a few more times to get the block clear.
I also highly recommend you pull the thermostat out on your first drain and put the housing back without the thermostat. It only takes about 10 minutes and will save you 2.5 hrs or so in doing this whole procedure.
Ok now put the lower hose back on and the drain plug back in the block if you removed it. This is the procedure you will use each time to drain the system, except you will not touch the thermostat again until you're finished the whole procedure. Make sure that you set your heater to high while doing this to flush out the heater core as well.
Fill the cooling system with tap water, start the truck and let the water circulate for 5 minutes. (if you did not remove the thermostat you must run the truck until the thermostat opens + 5 minutes to circulate. This takes 15 to 20 minutes each cycle and is why you should just remove the thermostat) Stop the engine. Drain the system and repeat the flush.
Now add at least 1/2 gallon of Restore and fill with tap water. Drive truck or run on high idle for 60-90 minutes. Drain and flush 3 or 4 times.
Add 2qts VC-9 or 1/2gal of Restore Plus, top with tap water, and drive the truck or run on high idle for 60-90 minutes. Now drain and flush until flush water comes out clear and clean. When you get clean flush water, flush 3 more times using distilled water if you are draining the block or 5 times if not. This is to replace any tap water in the cooling system with distilled water and very important.
After your final distilled water drain it is time to put the thermostat back in. I recommend you install a new thermostat at this point. They are only $20 or so and it is good maintenance procedure to do so. Fill with 3.5 or 4 gals of ELC concentrated coolant and top off with distilled water. Drive the truck or let run for a while topping off with distilled water. Check the truck over the next few days and top up as required while any air left in the system works its way out.
Keep some 50/50 ELC on hand to use to top off the cooling system from here out and you are good to go.
new t/stat from Ford it should all come together (housing-t/stat-o-ring) in a box. The part number is RT-1169
Here is the Restore Product from Cummins dealer
http://www.fleetguard.com/pdfs/produ...LI33024-GB.pdf
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 8 Old 04-13-2011, 12:56 PM Thread Starter
New Cooler & EGR Delete,CAT ELC less than 5k ago .. truck is not hot , I ckd w/infared temp gauge.and I have SCTx3 & not throwing any codes ..if sending unit is bad or has a short ,I need to know if this is whats making fan cycle rapidly ...basicly a sensor has to trigger the fan ..is it the ECT Sensor is what I'm asking
post #4 of 8 Old 04-13-2011, 11:27 PM
OK if you are not getting hot i would get a new ECT Sensor you need a place to start and easy to get to.
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
post #5 of 8 Old 04-14-2011, 05:29 AM Thread Starter
Yea gonna do that today , But can anyone VERIFY which sensor controls the fan clutch ?? or is it PCM Controlled ??
post #6 of 8 Old 04-14-2011, 10:29 PM
but this may help around page 9
http://www.fordtechservice.dealercon...03-25-Book.pdf
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
post #7 of 8 Old 04-20-2011, 10:20 PM
03Powerstroker6.0's Avatar
Intake air temp, trans temp and coolent temp control engine fan through the pcm.
03 F350 Lariat CC LB 4x4,
straight Pipe 4" exhaust 6" tip
3" front lift
5100's bilstiens
high idle mod
Sct Gearhead tuned,
EGR deleted
trans,fp, boost, egt, ect, eot gauges
vgt switch
2low Switch
Zoodad
315/75/16 baja claw
Custom trac bars
coolent filter
ccv mod
arp studs by me
afe stg 2
fuel bb mod
Hids
Smoked LED tails/3rd
Harley headlights
Smoked led tail lights
08 T gate
Upgraded banjo bolts
2 12" subs/6x8 infinity speakers
JD cool Gaurd II coolent
03Powerstroker6.0 is offline
post #8 of 8 Old 04-21-2011, 04:55 AM Thread Starter
Replaced the Coolant Temp Sensor , so far fan is acting " normal" again ...we will watch and see if this is the culprit ..Thanks !
