TSB 04-23-08 - Ford Powerstroke Diesel Forum
Old 07-24-2007, 06:29 AM
Send a message via Yahoo to thunderinms
TSB 04-23-08
How hard is it to fix this?
Thanks,
GG
04 F-Series/Excursion Power Steering Noise:
Some trucks may exhibit a moan or grunt noise from the power steering when turning the steering wheel, usually more pronounced on left turns. The noise may sound like it's coming from the steering gear or column. Replace the hydraulic pressure line running from the brake hydroboost to the steering gear, and the return line running from the gear to the cooler. Take care to prevent any debris from entering the hydraulic system.
Pressure line: 4C3Z-3A719-C
Return line: 4C3Z-3A713-A
TSB 04-23-08
Old 12-07-2009, 04:56 PM
Just bumping to find some replies, I believe I have this same problem. Thanks.
