blew off turbo hose?
I was on my way to a big mudhole yesterday with our 4-wheelers and my truck blew one of the pipes of the turbo, Its the one that runs to the turbo from the left side and attaches right to the front off the turbo, I had a 7/16 wrench on me so I put the boot back on and 15 miles down the road it blew off agian!! I put its back on and its ran for about 70 miles now.
What causes this? Could the clamps just have wore out (it looks rough)? Or do i have some other gremlin in this thing, like EGR sticking? |
The best thing you can do is clean it up really good let it dry. Then soak it with some hairspray put it on and retighten it
the same thing happened on my brother's dmax. I felt the tube and when it blew off it hit something hard enough to flatten a very small part of the flange... we bent it out a little to get a more uniform circular flange, cleaned it off as best we could, and tightened the crap out of it. So far it has not happened again. Clean it well and look to see if there are any dents in the flange... hope that helps
happens a lot because the boots soak in all the oil.... clean it good with some degreaser and put it on but eventually will have to be replaced because you wont be able to get all the oil off since it soaks in.....
Once the boots blow off toss them in the garbage . They usually wont hold anymore. I have tried to clean them off and it just wont last.
throw that one away if it looks rough , go to ford and by the updated one ,it has orange liner on the inside , not a bad idea to replace clamps also, there is a chance that the turbo can cause these tubes to blow off , ive seen a sticking turbo cause overboost and blow tubes off , if it seems to be running ok then , just go ahead and replace the boot , and give that a try first
