starter testing - Ford Powerstroke Diesel Forum
Old 01-11-2011, 12:01 PM
starter testing
I am trying to determine if my starter is going bad in my truck what is the procedure for testing a starter still in the truck and what should the voltage range be
Old 01-11-2011, 12:04 PM
Illiana Chapter Director
What kind of problem are you having?
Old 01-11-2011, 12:08 PM
The motor seems to not be spinning over as fast as it was a couple weeks ago I also had two new batteries put on yesterday
Old 01-11-2011, 12:18 PM
The A/C compressors are know for dragging when starting on the 6.0. The clutch gets out of adjustment. You might check and see if the clutch is engaged and turning when cranking the truck. You can shim the clutch on the compressor.
Old 01-11-2011, 12:33 PM
To be a little more specific about it when you first crank it the first few revolutions you can tell its draggin but it seems to pick up right before it cranks and it only seems to do it when its been sitting for a while
Old 01-11-2011, 12:38 PM
I'd still check the compressor. More common than the starter. I don't know what kind of voltage you have to test for at the starter. Maybe a tech. will chime in and help out.
Old 01-11-2011, 12:42 PM
I will check the compressor If that's what it is I will be chiming back in on how to shim ity
Old 01-11-2011, 03:46 PM
I checked the compressor and it was not spinning on startup would like to know about the starter if anybody has any other ideas chime in please
