The truck has been get harder to start lately but i figured it could be on account of the frigid weather im also two days away from selling I need this fixed ASAP. I was driving the truck around for nearly half an hour turned it off at the grocerie store came out after 25 minutes cranked strong no start. FICM was rebuilt by swamp and the HPOP fitting was replaced with the stronger one by ford when the injectors were installed. Right now im waiting on AAA to get here and tow it. When I was cranking it over I did notice it showed positive oil pressure so im praying it isn't the HPOP. I also noticed after cranking for maybe 10 seconds it threw a message saying TBC fault which I believe is trailer brake . Please any help would be great.
Thank God just needed a new battery old one tested good wasn't pushing enough CC amps
DId you replace both batteries? Seemed like you mentioned it was turning over strong at the store....hmmmm
there is a sensor that goes out and causes a no start warm condition. IPR? ICP? one of those I think. You should be able to search for it
Im with the horse on this one. It wouldnt be cranking strong if one battery was bad. |
now if you said the dummy plugs were updated with injectors then that makes sense |
Last time same hapend to my i rapleace and cmp and other one crankshaft position sensor and was the same after i spray starter fluid to my filter my wife starts and is running thru now no problem if start then you now if is belt good in engine
