"Open Doors" Light Issues - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-09-2011, 11:18 AM Thread Starter
FIRST_TIME_DIESEL's Avatar
Hey everyone i have a hopefully quick question. Has anyone had trouble with their door sensors? Right now no matter how many times i shut each door, the red light shows that i have doors open. I even had to remove my dome light. Does anyone have any suggestions? My truck is an 04 xlt extended cab 6.0 auto if that makes any difference. Thanks
04-F250 6.0
-coolant filter
-egr delete
-revised oil cooler
-batmowheel in 04 stock turbo
-5" Ausi Stacks
-Sct x3 with tunes from Mkm
-Edge Insight CTS
-8" skyjacker Z-Link
-38x16 r16.5 tls's
-warn hubs
FIRST_TIME_DIESEL is offline
post #2 of 8 Old 01-09-2011, 03:58 PM
nylyon's Avatar
Take WD-40 and spray in each door latch (on the door) straight down into the mechanism. Then open and close each door several times should fix ya right up.
- Karl
2003 F-250 Crew Cab Short Bed Lariat PSD 6.0 Automatic FX4 Edge Insight with EGT Probe. Coolant Filter. All 6.0's need gauges
nylyon is offline
post #3 of 8 Old 01-09-2011, 04:06 PM
STRKTHS73's Avatar
Send a message via AIM to STRKTHS73
^ ^^^^ agreed works everytime
06 F-350
4" turbo back silverline exhaust
KMC XD series spy wheels
35" toyo m/ts, 5% window tints
4.5 rough country lift
triple pillar egt, boost, and trans temp
edge cts insight
CAT coolant swap at 30k
Sinister Coolant Filter
SCT X3 with custom tunes by vivian at QT
STRKTHS73 is offline
post #4 of 8 Old 01-09-2011, 04:14 PM
assistant director
thbd77's Avatar
^^^^ yep what they said
Name-Troy Lincoln
96 F-250 4X4 stroked xcab shortbed 5 speed
01 EXCURSION LIMITED 4X4 V-10 brute force intake dual exhaust
02 EXCURSION LIMITED 4X4 stroked ts 6 position 4" dp and duals hers now
06 F-250 4x4 6.0 auto lariat crew cab short bed Dads ride
thbd77 is offline
post #5 of 8 Old 01-09-2011, 05:45 PM Thread Starter
Thanks, i appreciate it! I will try that later tonight. Is this a common problem or something that at least can be prevented by occasionally spraying some wd40 in there?
04-F250 6.0
-coolant filter
-egr delete
-revised oil cooler
-5" Ausi Stacks
-Edge Insight CTS
-38x16 r16.5 tls's
-warn hubs
post #6 of 8 Old 01-10-2011, 06:14 AM Thread Starter
That didnt seem to fix the issue. However i did forget to mention that my driverside rear door doesnt open. When i bought the truck i was told that the latches were stuck and that it would simply open after it had been soaked with liquid wrench. Well i got the top free but the bottom still wont unlatch. Does anyone think that this could also be causing issues? I do plan on fixing that once the weather is warmer, and it hasnt given me any issues yet. I will try again tonight with the wd-40. Thanks much
04-F250 6.0
-coolant filter
-egr delete
-revised oil cooler
-5" Ausi Stacks
-Edge Insight CTS
-38x16 r16.5 tls's
-warn hubs
post #7 of 8 Old 01-10-2011, 06:48 AM
nylyon's Avatar
I do not know how a super cab works, that is if there is a door switch on the back doors or not? The door switch on a crew cab is on all 4 doors and the switch is closed when the door is closed. Sometimes that sticks which is why the WD-40 works. My passenger side recently did this and the door switch was new within the last 3 years.
- Karl
nylyon is offline
post #8 of 8 Old 01-10-2011, 06:57 AM Thread Starter
Well i assume that if several people suggested the same thing it will work. I just have to do it again, its not really a big deal right now because there is almost no power draw when the truck is off because of the light removal. I just hate when my dash has warning lights. I'll try again tonight and see if that helps at all. I do have to take my rear door apart anyway, so we'll see if that has anything to do with it as well.
Also, i used liquid wrench the first time (couldnt find the wd40) and wd40 the second time (it was def in the truck under stuff). Ill post more when i get off work and have a chance to re-spray it agian. Thanks for all of the help.
04-F250 6.0
-coolant filter
-egr delete
-revised oil cooler
-5" Ausi Stacks
-Edge Insight CTS
-38x16 r16.5 tls's
-warn hubs
