HEAT NOT GETTING HOT - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-05-2011, 06:49 PM Thread Starter
jason's Avatar
I HAVE A 2005 F-250 6LITER DIESEL. MY HEAT WILL BARELY GET WARM. THOUGHT IT WAS THE HEATER CONTROL VALVE UNDER THE HOOD. REPLACED IT, DIDN'T FIX MY PROBLEM. INSIDE CONTROL SWITCHES FROM VENTS, DEFROST, FLOOR, ETC..... TRUCK TEM IS RUNNING NORMAL. HELP !!!
THANKS, JASON
jason is offline
post #2 of 8 Old 01-05-2011, 09:32 PM
THANKS, JASON
a stuck t/stat maybe
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 8 Old 01-06-2011, 02:01 AM
2 stroker
yep. Stuck thermostat.
2004 CCSB -mods:
* H11 head studs
* ZooDad Mod w/ Custom Intake Inlet & Grill
* Banks High Ram Air Intake Manifold Elbow
* Banks Techni-Cooler Intercooler
* Banks 3.5" Boost Tubes
* (3) Dieselsite 3.5" Banks Replacement Boots
* FICM Programmed by PHP
* Stage 1 Regulated Return Fuel System
* 0-100psi Fuel Pressure Gauge at Regulator
* Adjustable Fuel Pressure
* EGR Delete
* Banks 4" Monster Dual Exhaust
* Edge Insight CTS
ImaPoser is offline
post #4 of 8 Old 01-06-2011, 02:51 PM Thread Starter
jason's Avatar
JUST INSTALLED BRAND NEW THERMOSTAT, DIDN'T FIX MY PROBLEM. COOLANT LEVEL IS GOOD TOO. ANYBODY KNOW ANYTHING ABOUT THE TEMP BLEND DOOR??? TALKED TO A LOCAL DEALER MECHANIC TODAY, HE SAID IF THE THERMOSTAT DIDNT FIX IT , THAT IT MAY BE THAT????? ANY INFO APPRECIATED.
THANKS, JASON
jason is offline
post #5 of 8 Old 01-20-2011, 04:28 PM
StrictlyDiesel's Avatar
I have the same truck, same year, same problem. Its never been able to blow a lot of heat in the winter. I can start it in the morning and let it idle for 10 mins and it heats just enough to start defrosting my windshield....but on my half hour drive to work the heat is still cranked and its still cold. I put a massive piece of cardboard to block my rad and it doesnt seem to help.
Mine's an XLT, my buddy has the lariat which apparently has an added electric heater in the dash to speed things up and keep the drivers warm.
08 F350 6.4L Crewcab Shortbox
Elite fuel bowl delete
Elite diesel ported fuel rail
Flo pro egr delete
Air dog 2
S&B intake
Aerospace fuel regulator
Head studs
Upgraded piping
Banks intercooler
Elite diesel tow atmosphere turbos
37" tires
3.73 gears
6" lift, 4-link up front, blocks in rear, no rear ladder bars
Smoke'EM Black!
05 F250 6.0L Powerstroke Crewcab Shortbox
BullyDog GT Tuner
Catback 4" Exhaust w/ 6" Stacks
Custom 3" Lift
35's, Rims, Flares
Amzoil
StrictlyDiesel is offline
post #6 of 8 Old 01-20-2011, 04:57 PM
What's temp gauge say?
Kickery220 is offline
post #7 of 8 Old 01-21-2011, 03:36 PM Thread Starter
jason's Avatar
FINALLY GOT MY HEAT BACK. I REPLACED MY HEATER CONTROL VALVE,& THERMOSTAT. DIDN'T THINK I COULD BE THE HEATER CORE, BECUZ BOTH HOSES WERE HOT, GOIN IN & OUT. I TORE OUT MY GLOVE BOX, CHECKED THE TEMP BLEND DOOR, AND IT WAS WORKING FINE. FELT OF THE HEATER CORE, AND THE TOP WAS HOT, BUT HTE BOTTOM WAS JUST COLD METAL. SO I TOOK MY TRUCK TO MY BUDDIES LOCAL RADIATOR SHOP, AND HE FLUSHED THE HEATER CORE, AND NOW THE HEAT GETS HOT. HE SAID THAT HE FLUSHED OUT ABOUT 7 FORDS THE SAME WEEK FOR THE SAME PROBLEMS. HOPE THIS HELPS KEEP YA'LL WARM.
LATER, JASON
jason is offline
post #8 of 8 Old 01-21-2011, 09:54 PM
LATER, JASON
Boy the old Ford Gold Cxxp coolant it will screw up more than just the oil cooler can't figure that one out
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
