Replacing the clutch pack in the posi unit - Ford Powerstroke Diesel Forum
Old 01-04-2011, 10:10 AM
OK, I'm pretty sure there was someone that did the clutch pack replacement on the limited slip diff and done a write-up on it on this site with photos. I remember seeing it a while back, but I've used the search function here for a few days and I'm tired of it.
Does anyone else remember this post that could direct me to where it's located? I'm about to tear into mine and would like to see what the pre-set tolerences are on the clutch pack. I believe in the write-up I am referring to the guy tightened the tolerence up a thou or two??
Old 01-04-2011, 05:32 PM
Finally found it. The one on this site didn't have photos but it was the one where they added shims.
2003 F250 limited slip quit working
The one with photos was on another site, and on the 10.25, but still the same scenerio.
Sterling 10.25 Trac lock rebuild
I thought I'd post it in case anyone else should need it.
Old 01-04-2011, 05:33 PM
Now I'm Strokin6.4Liters
Feedback Score: 8 reviews
Where are you at in TN?
Old 01-04-2011, 05:51 PM
Bout 15 minutes from you. HAMPTON
Old 01-04-2011, 05:58 PM
Sounds good bud. There isn't many of us on here from our neck of the woods
