No OBD port voltage
I don't have any voltage at the OBD port. Checked all fuses and connections, everything seems fine. Can't check codes or change programs. Any help?
Any ideas?
what fuses did you check. If I remember correctly, doesn't the OBD2 port tie into one of the power outlet fuses. I would re-check those and change the bad fuse and try again. I think that is the right fuse, it has been a while since I changed it out. Hope that works.
the OBD2 port is tied with the cigarette lighter fuse.
And that applies to ALL OBD-II compliant vehicles as well, if we are talking about pin #16 of the DLC. This pin is the "hot at all times" pin on every OBD-II vehicle.
That’s the same answer I got from the dealership so I would assume that everyone is correct, but the only problem I have is that both the cig lighter and the aux have power and every fuse in the truck is good. Appreciate the help. Any other ideas or experiences?
